EGT Sensor Resistor MOd
Old Jan 18, 2005 | 03:47 PM
Smooth_Ej20's Avatar
Car Info: 2004 Wrx
Question EGT Sensor Resistor MOd
OK so i bought the 2.2k-ohm @5watt resistor for my failing EGT sensor on the up-pipe. My only question is this, there are 4 wires on the sensor clip, 2 black (should be ground) 1 white and 1 blue. So which way do i run the resistor? Blue to white, Blue and white to black? I dont really mess with electrical stuff so please help me out guys.
Old Jan 18, 2005 | 07:42 PM
joubtt's Avatar
Car Info: 00 2.5RS
I haven't done it yet but check www.scoobymods.com
Old Jan 19, 2005 | 12:29 AM
That's 2.2k ohm, 1/2 watt resistor. Make sure you got the right one before you plug it in. And the uppipe harness connector, which is right next to the boost solenoid on the passenger side strut tower, only has 2 holes. What year is your WRX?
Old Jan 19, 2005 | 02:45 AM
wrx10404's Avatar
Car Info: 04' wrx
I think he's got the O2 sensor plug. If i remeber the EGT sensor is only two wires.
Old Jan 19, 2005 | 09:42 AM
Car Info: 2004 Wrx
are you sure cause i followed the wires from the EGT sensor in the side of the up-pipe and all the wires lead to it. I do have the right resistor though i just forgot the decimal point.
anthonymx
Sep 24, 2011 01:58 PM
A.V.E.
Apr 14, 2011 07:49 PM
stets
Hawaii Classifieds
17
Jan 17, 2011 07:24 PM
spdkills
Jan 25, 2003 03:48 PM
