EGT q&a here
Old Apr 16, 2004 | 01:18 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Originally posted by 92legacyej22t
I'm going to be running my EGT in the up-pipe too because my CES Racing up-pipe is pre bunged there for it already.
Hey mexicanpizza, do you really think the exhaust gases cool that much from the #3 port to the up-pipe? I don't, that is unless you have inadaquate heat shielding.
I'm nothing more than an armchair/internet tuner-mechanic guy...but every serious person taps the manifold. All the first-gen uppipes had EGT bungs...now most of them don't.
And I also think tapping #4 is becoming more important (at least on the WRX) because it seems to be the hottest running cylinder.
I mean it's a heck of a lot easier to tap the uppipe if you just want a relative measurement....but I would guess from a tuning point of view...the temperature measured in the uppipe means less than the manifold temp.
Old Apr 16, 2004 | 04:23 PM
92legacyej22t's Avatar
Car Info: 92 legacy turbo 5-speed,98forester S 4AT
Ya, you're right that under the most ideal circumstance you'd want it in the manifold as close to the cylinder as possible. I always thought that #3 was the hottest and tended to run the leanest but that seems to be under some debate lately. Unless you're running at the limits of your setup and internels though I don't think that the extra 18" of pipe from the passengerside manifold to the up-pipe is going to cause a significant enough cooling of the exhaust gases (this is of course if you're bunging the #3 port though not the #4) to make that big of a difference.
But like you I'm not a professional tuner or anything and if the big boys are saying that it really makes a big difference then it probably does. For me though unless I start pushing some very serious numbers I think the up-pipe will work fine.
I've actually even heard a few different people say that you should put the EGT just after the exhaust turbine (in the DP) on a turbo setup because of the heat caused by the turbo and not in your manifold. :/ I could see this if it was a second EGT and not your primary but not if it's your only one. Has anyone else ever heard that?
Old Apr 17, 2004 | 08:22 PM
ride5000's Avatar
i'm with MP on this one... #4 seems to be the problem child. put it close to the most common failure.
no up pipe cat will reduce egts about 50-100 degrees farenheit. more effecient evacuation of exhaust gasses is to blame.
jm2c
ken
rwheelz
Apr 23, 2005 07:11 PM
WRXcellent
Apr 19, 2005 02:23 PM
Seranin
Jan 20, 2005 09:57 PM
sub-sonic
Apr 24, 2003 09:37 AM
spdkills
Jan 25, 2003 03:48 PM
