ECU=Pissing me off
Old Apr 22, 2003 | 01:42 PM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
there's nothing wrong w/ur car, that's how it shoulda came.....boost is limited in first and second, just as you describe. but not sure why it was hitting full boost and now it tappered off, maybe cuz you've been taking it easy on throttle?
there are some car who's ecu will allow full boost in all gear. for some reason, mine does......definitely not complaining
Old Apr 23, 2003 | 03:36 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
There is not enough load in the lower gears to get full boost in the WRX. Now if you get an aftermarket boost controller, you can force it too
To verify that your car is making the right amount of boost you need to do either a 3rd or 4th gear pull and see where the boost is at at around 4k RPM. It should be at the 13psi .or .1 Mpa range in your case.
Until then it's normal as stated above by capt'n'caveman
Lurk
Jan 15, 2005 10:22 AM
bwendelburg
Aug 18, 2004 03:51 PM
blueberryrex
Apr 17, 2004 02:25 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
suby_dude
Aug 1, 2003 10:01 PM
