DP heat shield?
Old Apr 11, 2004 | 07:24 PM
ScoobyBoy's Avatar
i would have to say its useful to have on, especially if you live in some hot climate like hawaii.
Old Apr 13, 2004 | 12:40 AM
supra_man's Avatar
what would happen if i leave it off in the long run?
Old Apr 13, 2004 | 01:01 AM
ScoobyBoy's Avatar
just lots of heat soak for your intercooler.
edit for spelling
Old Apr 13, 2004 | 02:24 PM
myroncuz's Avatar
Originally posted by Mach5WRX
Cut the stock heat shield to fit the new down-pipe.
thats what was done to mine.
Old Apr 14, 2004 | 08:44 PM
blaznasn's Avatar
i just made a new one out of some aluminum, and painted it with high temp ceramic paint. today i started to put a chimney on it, hopefully i'll finish it tomorrow.
Old Apr 14, 2004 | 09:21 PM
supra_man's Avatar
whats geat?
Old Apr 14, 2004 | 09:24 PM
meilers's Avatar
That is a turbo heatshield, not a downpipe shield. It will keep turbo heat from rising to the intercooler, but it won't block heat from the DP specifically.
From what I've read, the best bet is to get your DP Jet-Hot coated or wrap it with insulating wrap (usually called turbo or engine wrap). Both of these are fairly cheap solutions, though for the Jet-Hot coating, you will most likely have to ship the DP somewhere, which means your car will be out of action for a few days.
Here's information on heat insulation coatings:
http://www.jet-hot.com/
When I swap out my uppipe and DP, I am going with coated and insulated pipes; anything to keep the under-hood temps down is a good thing, even if you don't plan to do track runs. As it is right now, my engine stays at operating temp THREE HOURS after my 22-minute drive to work, and makes "ticking sounds" for a full half hour after I pull in.
Old Apr 14, 2004 | 09:32 PM
psychobooe's Avatar
Just a word of warning on coating and wrapping, it is my understanding that this could lead to cracked pipes. Both methods do an excellent job of trapping heat and they might do too good of a job. This excess trapped heat could lead to cracks. Just my 2 cents.
psycho
Old Apr 14, 2004 | 10:56 PM
DJTEN4's Avatar
Car Info: 03 yellow wrx
i have heard that too... i got my old heat sheid to fit around the helix dp with some cutting and bending.... i am also taking a dp heat shield from over the cat and am going to custom weld it on my helix so it looks like a cat, maybe i will post some pictures, but it should look pretty cool, and relatively stock lol
Old Apr 14, 2004 | 11:15 PM
meilers's Avatar
psycho
The Jet-Hot coated pieces are rated to 1,300 degrees, and are used in miltary applications. The only way I could see heating causing a problem is if you have *uneven* heating (something that causes a hot spot or cool spot, like an exposed uncoated area) accross the pipe. That's why cast-iron pipes are popular, because they heat very evenly. Ever use a cast iron frying pan?
Old Apr 15, 2004 | 01:14 AM
ScoobyBoy's Avatar
i heard it was better to coat the inside rather than the outside.
Old Apr 18, 2004 | 09:07 AM
meilers's Avatar
Check the site. They coat inside and out.
Here's the one I am going to get:
http://www.clubwrx.net/forums/showth...threadid=56327
Old Apr 18, 2004 | 04:19 PM
blaznasn's Avatar
yes, please post some pictures, i tried fitting it over when i installed mine, but when i tried to rebolt the two halves back together, there was a larger gap than i expected.
Old Apr 19, 2004 | 04:20 PM
HRMax's Avatar
Car Info: 2002 Black WRX Sedan
What would one expect to pay to have a downpipe coated? Is coating efficient enough to leave off the heat shield? Any good places to have it done?
Old Apr 19, 2004 | 05:17 PM
NewShockerGuy's Avatar
Arrow
I just bought the jeremy's (speedmonkey) chimney heatshield... it's AWESOME quality! I can't wait to put it on once my tbe goes on... I defintaly recommend it!
-Nigel
moto96793
Hawaii Classifieds
Mar 15, 2015 07:38 PM
akdmx
Jan 26, 2009 09:32 AM
gtfaded
Mar 23, 2007 07:08 AM
scottm1978
Subaru OEM Parts For Sale
Sep 23, 2003 05:05 PM
PimpWagon
17
Dec 14, 2002 12:00 PM
