low boost after the 3/16 to stock mod
Old Apr 10, 2004 | 05:53 PM
DizzyWRX's Avatar
I'm not sure if this will work, but try resetting the ecu by disconnecting the neg terminal of the battery. The ecu might be restricting your boost since it was seeing the boost spikes when you had the 3/16 mod in. In other words, ithe ecu learned that boost was getting too high, and then changed it's settings to actuate the wastegate earlier, and that could be why you're only seeing 9 lbs boost. I could be totally wrong. Just an idea i guess.
Old Apr 10, 2004 | 09:15 PM
DizzyWRX's Avatar
Glad your boost is right again. Too bad i couldn't help.
Old Apr 11, 2004 | 09:37 AM
hypa's Avatar
Car Info: 02 wrx wagon
I had the same problem when I un-installed my MBC. I put the oem hoses back in, but they were actually backwards, and all I got was 9psi.
Old Apr 11, 2004 | 03:47 PM
DaveDangerous's Avatar
Car Info: GG IX MR
I just took my mbc off and i have the same problem now...can someone post a pic of what its supposed to look like.
Old Apr 11, 2004 | 04:04 PM
RussB's Avatar
Car Info: $200,000 sports car
the hose with the brass pill goes from the compressor to the T.
it's possible that if you bypassed your stock boost solenoid with your MBC that the solenoid went bad. it's been known to happen.
Old Apr 11, 2004 | 07:46 PM
Car Info: GG IX MR
What should i do if the solenoid went bad? have all the hoses in the right order, but it only boosts to 9psi, and when i accelerate onto the highway in 3rd or 4th the turbo spools from 9 back down to 5 and back to 9 and then back down again. Should i try to reset the ecu?
i<3dirt
Oct 20, 2014 10:26 AM
djwonder925
Apr 21, 2013 12:05 AM
Mobutusan
Apr 2, 2008 11:38 PM
tiberus667
Feb 24, 2004 09:07 PM
JSiwek
Jan 24, 2004 02:44 AM
