does intercooler size depend on turbo size???
Old Mar 1, 2004 | 08:42 AM
methodical's Avatar
Car Info: 2002 wrx wagon
hey guys and gals im just wondering if i got a vf 34 turbo, would the turbo xs TMIC work properly with it? my friend told me that i would need to get a FMIC for a turbo that size. however i dont want to get a front mount. any help would be greatly appreciated. THANKS.
Old Mar 1, 2004 | 10:48 AM
ride5000's Avatar
you can run a 34 with the oem top mount just fine. will you get the same performance as you would with an uprated tmic? no. but for a turbo that size you won't see a hell of a lot of difference.
jm2c
ken
Old Mar 1, 2004 | 02:02 PM
mario's Avatar
jm2c
ken
What?!?! i think you need to do some research there buddy
Old Mar 1, 2004 | 02:03 PM
Daredevil's Avatar
you can use the turboxs tmic and it'll work fine, you can even use the stock i/c and it'll work fine, but not as well as if you had a bigger i/c of course
Old Mar 1, 2004 | 10:34 PM
methodical's Avatar
Smile
thanks that clarifies alot for me
Old Mar 2, 2004 | 01:22 AM
Why do you say that? The OEM top mount is a lot better than the internet gives it credit for. On a turbo the size of a VF34 (which isn't very big- I wouldn't call any turbo that requires a boost taper before redline "big") changing the topmount won't give you huge power gains. 10-15 hp max, and that's peak, not across the board. While 10-15 hp is not insignificant, I wouldn't spend $1000 to get it.
Old Mar 2, 2004 | 09:45 AM
mario's Avatar
Really? I always saw a larger TMIC as for safety not really expected for a whole lotta horse power. So do you think that you could run 17 psi all day w/ 34 and stock TMIC on 88 degree day like here in hawaii? I think it gets to be about 92 degrees at our track during track days and i could see my self running that much boost w/ the stock TMIC safely. What do you think
Old Mar 2, 2004 | 10:52 AM
If that's an EJ20, you could peak at 18 as long as you have sufficient fuel and spark control and haven't defeated the knock sensor.
Old Mar 2, 2004 | 11:11 AM
RussB's Avatar
Car Info: $200,000 sports car
SCC did an interesting review comparing the OEM TMIC with a larger aftermarket TMIC. while the OEM heats up faster, it also cools down faster. the aftermarket didn't heat up as fast, but it remained hot once it got there.
Old Mar 2, 2004 | 12:29 PM
mario's Avatar
I'm glad i do i haven't run my car yet w/ my current stg4 set up but i guess we'll see. Thanks BANSUVS for the education
Old Mar 2, 2004 | 01:14 PM
ride5000's Avatar
exactly my opinion.
ken
Old Mar 3, 2004 | 05:43 PM
Re: I did spend the money
Originally posted by Mathius
For the additional HP + cooling and safety on a MRT TMIC..I didn't put in my PWR radiator for HP gain...Keeping things cool = more safe power gains.
The problem with large aftermarket intercoolers is that once they become heat soaked, they stay heat soaked for a very long time and intake temperatures suffer. The observations made by Dave Coleman in the APS top mount vs. stock top mount artice in SportCompactCar apply to nearly every large-core, bar-and-plate IC there is.
