coolant mix
Old Oct 9, 2003 | 12:55 PM
4080wrx's Avatar
use distilled water
Old Oct 9, 2003 | 02:04 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Minerals may be good for you but they're not good for your cooling system. May be no harm done depending on what is actually in that water and how much, but the best thing is to use distilled water as specified. If you want to be certain this won't cause any problems then drain it and refill it again with the right stuff.
Old Oct 9, 2003 | 03:37 PM
02wrbluewrx's Avatar
Car Info: 2002 WR Blue WRX
maybe im just ignorant but whats the reason for mixing water and coolant and not just putting in straight coolant
Old Oct 9, 2003 | 03:51 PM
Mulder's Avatar
Water is actually more efficient for heat transfer than antifreeze. A system filled with pure antifreeze wouldn't cool very well. The antifreeze is necessary to lower the freezing point and raise the boiling point of the coolant, as well as for the anticorrosion additives, but for proper cooling system operation you don't want to go over a 50-50 mix.
WindCloud
Aug 5, 2004 01:08 AM
Krinkov
Feb 29, 2004 07:50 PM
SuperHawk
Oct 13, 2003 09:15 AM
Jay784
Sep 15, 2003 11:33 PM
