Common turbo upgrade?,,
Old Mar 3, 2006 | 01:22 AM
Rice Rocket's Avatar
Exclamation Common turbo upgrade?,,
WHat you guys using for upgrading your turbos?
I've got a TD05 which I heard alot of g'boxes going using these so not sure if i'm going to use it.
Cheers
Ricey
Old Mar 3, 2006 | 07:27 AM
Egan's Avatar
Gearboxes go out because of higher than stock power. Any aftermarket turbo is going to give you higher than stock power levels, so it's not a TD-05 specific issue.
That being said, and realizing that gearbox failures are hit or miss, the turbo you choose depends on what your goal is. A common, good upgrade is the VF series which are a direct fit. A lot of folks use the VF30/34. For higher power you can look into 18g/20g/FP Green/APS turbos.
Old Mar 3, 2006 | 01:42 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
vf34
Old Mar 3, 2006 | 02:13 PM
subie OCD's Avatar
Car Info: 04 STi
Banging gears/hard shifting and hard launches should be avoided if you want to prolong the life of the gears/tranny.
i have a vf 34
i want something else
RAAZ227
Feb 18, 2004 07:22 AM
1Slow///M3
Sep 5, 2003 07:28 AM
lawrencebird
Aug 26, 2003 01:49 PM
Rekisito
Mar 17, 2003 01:33 PM
gpatmac
Dec 25, 2002 11:08 PM
