colder plugs (recommended for mildly modded engine?)
Old Oct 27, 2006 | 11:42 AM
ikes wrx's Avatar
Car Info: 02 wrx
colder plugs
I've got a cobb AP stage 2 set up, should I be using a colder plug range than stock?
Also the car sees cold weather here in Canada
Old Oct 29, 2006 | 09:36 AM
the heat range has nothign to do with the temp outside almost
the heat range is the temp in the cyl.
some people say it helps out with detonation
Old Oct 30, 2006 | 04:22 PM
testes1010's Avatar
many people have ran into misfire issues w/ the OTS Cobb Maps, because they are not designed for colder plugs.....otherwise I'd recommed colder plugs for an aggressive custom STG2 tune...
Old Oct 31, 2006 | 11:44 AM
ikes wrx's Avatar
Car Info: 02 wrx
thanks for the info, I have a p0304 code going on right now, I just thought that colder plugs might help solve this
Old Oct 31, 2006 | 04:56 PM
testes1010's Avatar
check your #4 plug & coil pack....
Old Nov 1, 2006 | 12:01 PM
ikes wrx's Avatar
Car Info: 02 wrx
I've done that thanks, I've posted my woes in another thread "cel p0304"
I was just wondering about the plugs
Old Nov 10, 2006 | 10:33 AM
johsti's Avatar
Car Info: 2004 WRX Wagon PSM
True, but it can affect cold starts. You might have to turn the key a couple times when it's cold out. Once the engine is running, the plugs won't be affected by weather.
I'd recommend one step colder coppers. that's what I'm using on a tuned stage 2. They're cheap and work great. I've had the stock platinums, colder iridiums and now one step colder coppers, and there is no noticeable difference. If anything, the car seems to idle and drive smoother with the coppers. NGK/Copper/BKR7E/WRX/one step colder. the only downside to the copper plugs is they need to be changed about once a year.
Old Nov 12, 2006 | 08:14 PM
ikes wrx's Avatar
Car Info: 02 wrx
thanks for the straight up answer,
pleue
Jul 31, 2006 09:43 AM
Konrad_WRC
Feb 22, 2006 07:06 AM
PlatNmRex
Feb 17, 2005 03:06 PM
scapy2
Jul 26, 2004 05:11 PM
Chibby Goku
Jul 6, 2003 04:03 AM
