Clutch Problem ???
Old Jun 23, 2010 | 08:17 PM
Teddy's Avatar
Car Info: Subaru JDM Type RA
Clutch Problem ???
OK i rebuilt my tranny and put it baq in now i find that i cant make any gears once the car is started....wen i start it in neutral and try to put it in 1st it doesn go no matter how i pump the clutch.....and if i start it in 1st with the clutch in it'll roll forward slowly...if it is off i can select each gear including reverse easily
i have a twin disc exedy clutch kit with flywheel installed...never experienced this problem b4 cuz it be my pressure plate has gorn bad ? it isnt releasin the clutch disc far enough to stop the gears from spinnin for ez selection ?
Old Jul 22, 2010 | 01:28 PM
Labmonkey's Avatar
Car Info: 04' wrb WRX sedan
You may have put the clutch disk in backwards?! We did it on the first clutch my brother and I swapped on a honda with a six puck. We were in a hurry and weren't paying attention.
Old Aug 4, 2010 | 12:20 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
The disc is dragging on the pressure plate. Either you installed the disc incorrectly, or its damaged. You'll have to pull it back apart and inspect everything very closely.
-- Ed
burmis1
Oct 15, 2004 05:31 AM
RUDEBWOY
Jan 4, 2003 11:19 AM
sti101
Dec 30, 2002 02:00 PM
Top
