Clicking sound with cold engine?
Old Nov 5, 2003 | 08:59 PM
meilers's Avatar
The dealer/shop told me two things...
First of all, as many of you have noted, they feel this is normal Subaru engine behavior; it is the sound of the lifters. Gold star for the guy that diagnosed this earlier.
Second, the reason I am hearing it is not just because the engine is getting colder than before, it is because I switched to all-synthetic oil which has a lower viscosity and less sound- and vibration-damping ability.
I HATE the sound, however! It is loud enough that neigbors and co-workers turn their head as I go past. I feel like I am driving a Ford Model T...
Price you pay for synthetic oil?
Old Nov 5, 2003 | 10:11 PM
mmboost's Avatar
Please try my experiment, and see if its not the injectors. Have you ever actually tested this?
AFAIK, noisy lifters is never a healthy symptom. An affectation of synthetic oil? I certainly hope not. That would mean that synthetic oil protects less (against shock) than dino oil. If that were the case I'd think it useless, despite its resistance to breakdown.
jason
Old Nov 5, 2003 | 10:47 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
I thought EJ20 was a solid-lifter valvetrain....so it cannot be a case of hydraulic followers not boosting up.
Old Nov 6, 2003 | 01:35 PM
meilers's Avatar
jason
The mechanic I talked to said that he has 17 years experience working on Suby boxer engines, and they all clatter in cold weather. However, he does work for a dealership, so perhaps he's just hoping to charge me top $$ to rebuild my engine after it passes the 36,000 mile warranty :-)
I'm certainly not a lubrication expert, but it is my understanding that the lower viscosity of lubricant, the better; the lack of surface tension allows it to get deeper into smaller pores and cracks in engine surfaces -- and your pistons do not have to "fight" as much drag from the oil. Switching to full synthetic gave me an instant mini-power boost (according to my butt dyno).
Anyway, I have it in for service on Monday to fix a rattle behind the dashboard, so I'll corner one of the grizzled older mechanics (rather than the chap who works behind the service counter) and press them on the issue.
Old Nov 7, 2003 | 12:11 PM
mmboost's Avatar
5w30 is 5w30. Synthetic or dyno. I think your butt dyno is off Weight is weight and viscosity is viscosity, per its rating. If it was different, they would label it differently. The difference between similarly rated dino and synth is propensity to break down and not provide proper protection as heat increases.
jason
Old Nov 7, 2003 | 12:12 PM
mmboost's Avatar
Originally posted by Cynic
Cold morning valvetrain noise....its very common in all engines more so in V and Inline engines but common to all.....I have yet to own a vehicle that hasnt done this...once the engine warms up a little and the oil gets to the places it needs to be it stops....
I totally agree... but what's the clacking when its not cold <singsong>no one's trying "my" experiment</singsong>
jason
Old Nov 7, 2003 | 02:59 PM
meilers's Avatar
jason
Oh yes, I know the way oil is graded/labeled. I did in fact switch to a lighter weight when I went full syn. However, the syn oil does (according to some brochure!) have a smaller size at the molecule level, and to my fingertips seems to feel "thinner." It also seems to get dirty faster, or perhaps because of its lighter color shows the gunk more.
To be honest, I haven't tried your test because I don't own a long-handled screwdriver ;-). I'll try it with the tire iron, any long piece of metal should do the trick.
Old Nov 7, 2003 | 03:14 PM
mmboost's Avatar
Oh my God, be careful hahaha... no posting pics of holes in your head! Sudden jerk of the engine...
jason
Old Jun 2, 2004 | 05:28 PM
SnoHumper's Avatar
Car Info: sc300
its ur lifters... when its cold they are small and when they heat up they get to their operating size and fill up the gap. the gap when its cold makes them go click click click when the metal hits.
Old Jun 4, 2004 | 07:35 PM
jcorrao's Avatar
Originally Posted by meilers
I have a 2002 WRX just past 18,000 miles (I got it LATE 2002) and I have noticed something interesting... When I start the car in the morning, I hear a LOUD repetitive clicking sound (loud enough to be heard over engine noise and the radio) that sounds like it is coming from the "bottom" of the engine just forward of the firewall. The clicking is loudest when I have put in the clutch and the engine drops towards idle; under load, the sound goes away entirely. After about 5 minutes of driving, the sound is gone.
So, any candidates for the source of this noise? It isn't any of the belts, I suppose, because those don't click if they are damaged (they scream!). Anything to be worried about, besides sounding like a @!#* sewing machine?
is it when you just start up? I would tend to think it's normal when the engine is just started up when cold. Mine does it for a few seconds at that point. I have an '04 WRX.
Old Apr 21, 2007 | 12:26 AM
comi_cozi's Avatar
Car Info: 04 Wagon Silver
I have the same Problem i am thinking that my Exaust is the culpe-RAT iam thinking that there is a small gap and it heats up it seals it plus i was doing some work on my Engin put in new valves and i swear i dident have this before but i think eather the lifter or my exhaust its bothering and it is coming from under the turbo on my 04 WRX WAGON I i would still think that it should not be the lifters Just because not all cars have the isue and alot of people might have had there Exhast down pipes and sooo on workd on and prob like me dident replace the metalic gasket soooo HERRRS HOPING ill keep you guys up to date I am pretty much a Family taught Mechanic soo it will take me a good 4 hours to fix this problem if it is the Exhoust soooooooooooooooooo i hope this helps someone but not untill i doo the work maybe this week end or next SUBe UP and out!!
gzichy
Nov 28, 2012 11:37 AM
Thran
May 25, 2005 06:40 PM
debbid
Dec 28, 2004 09:56 AM
SuPraScOObY
Oct 20, 2004 03:21 PM
gpatmac
Nov 11, 2003 03:35 AM
