CEL Fix w/ cats
Old Feb 1, 2004 | 12:49 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
CEL Fix w/ cats
if i get sent to the state ref for a next-day smog test, can i slap on my stock dp and keep the cel fix installed or would i have to remove the cel fix?
thanks for the responses
Old Feb 1, 2004 | 02:33 PM
ScoobyBoy's Avatar
ive heard that you can leave it on, but im not too sure. did you get a ticket?
Old Feb 1, 2004 | 03:41 PM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
It depends on what cel fix you used? Did you do it electronicaly or mechanically?
If it is an electronic fix I would suggest removing it because if they put your car up on a lift and see the box you can get hit for a fairly large fine. If you are going to the state ref you need to take your car back to as close to stock as you can and remove anything that is not CARB approved.
It really depends on who does the inspection and what methods they use so I could be totally wrong. Good Luck.
-skooter
Old Feb 1, 2004 | 07:48 PM
thanks for the responses. i didnt get a ticket. i was just wondering.
OG_Kush
Aug 10, 2005 09:56 AM
OG_Kush
Aug 6, 2005 09:26 AM
WRX Rush
Oct 19, 2004 06:22 PM
esracer
Mar 16, 2004 11:56 AM
