CEL codes help.. ASAP..
Old Aug 30, 2004 | 01:19 PM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
Who did your turbo, injectors (which injectors are they), install?... I dont see a fuel pump in your mod list. Did they just start popping up or was there something installed then they started.
I would have someone do some EM ... tune that puppy.
Old Aug 30, 2004 | 06:32 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Did you by any chance recently do any work under the driver side dash, and happen to notice two green connectors that were unplugged and connect them together? These are diagnostic connectors that are supposed to be left unplugged, and when you connect them the result is what you are describing- a constantly flashing CEL and cycling fans and relays.
Old Aug 31, 2004 | 07:16 AM
Kwilson21's Avatar
There ya go.
nice.
-K
Old Aug 31, 2004 | 03:23 PM
RoadSpike's Avatar
why do i have the suspision that a few connections are loose from previous engine work maybe?
Check the sensor locations and if you have messed with the ecu harness its connections to. Can't hurt after all.
blkdout04
Sep 25, 2008 02:01 AM
edzwrx2
Mar 4, 2008 08:42 PM
yellow03 rex
Feb 25, 2006 04:54 PM
copracer288
Dec 6, 2004 05:16 PM
flanagan
Jan 2, 2003 10:05 PM
