CEL after installing boost gauge
Old Mar 15, 2004 | 01:43 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Where did you tap for boost? Are there any leaks there?
Old Mar 19, 2004 | 08:19 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Check for vaccum leaks. There is a hose attached to the bypass valve that connects to the throttle body under the IC, if you were pulling on that hose it might have come off.
If there is a vacuum leak you should notice the car not running right, the idle will be rough and power will be down.
Look for anything else that may have gotten unplugged or disconnected during the install.
It would also be very helpful if you can get the code read to see what it is.
Old Mar 19, 2004 | 08:05 PM
Mulder's Avatar
He's in Canada, may not have the Autozone option there.
i<3dirt
Oct 20, 2014 10:26 AM
djwonder925
Apr 21, 2013 12:05 AM
cdawg
Jan 4, 2008 03:44 PM
penguin051580
Apr 10, 2007 01:35 PM
mattr762
Apr 18, 2003 09:12 AM
