catback install problem. (HELP FAST!)
Old Dec 10, 2005 | 11:05 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
i'm installing my catback, and on my cat converter there are springs before the bolt, and i cant compress the springs enough to put it through the whole and put the nut on the other side, what did you guys do to solve this problem? thanks
Old Dec 10, 2005 | 11:11 AM
NeRdY DoRkUs's Avatar
use muscle.
only thing to it. put the ratchet on the head of the bolt, line it up with the hole on the flange n push with all your might and turn the ratchet. once u get 1-2 threads on your set.
or have someone stronger do it
Old Dec 10, 2005 | 05:23 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
did you take off the donut gasket ? because the spring bolts should go on pretty easy . . .
KendallRS
Dec 10, 2005 11:41 AM
crashnscar
Sep 18, 2005 08:50 AM
1wrx2goplz
Feb 9, 2005 09:14 AM
Foot_Tapper
Jun 15, 2003 02:32 PM
