Cam covers leaking oil...
Old Apr 20, 2004 | 02:23 PM
1WRX2NV's Avatar
Car Info: 02 STi
Question Cam covers leaking oil...
I noticed a few weeks ago that my car was leaving some small oil spots on my driveway. I finally jacked the car up and took a look.
The cam covers (black pieces in the front of the engine) look like they are leaking because there is oil along the seams...both sides!! The driver side looks the worst.
So, now I have a few questions...
what can cause this? and what damage will it cause? Also, will this take alot of money to fix?
thanks guys, any info will help.
-freddie
Old Apr 21, 2004 | 11:45 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
The cam seals leaking? Hrm...sorry to hear that freddie. I don't know how serious it is.
Old Apr 21, 2004 | 12:00 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Those are called timing belt covers. Not cam covers.
They cover the entire front of the engine, so there are a lot of things that can go wrong. The far left and far right part of the covers are the lowest point of the cover, so all the "leaking" oil gets accumilated there. Plus, the timing belt carries the leaking oil around and "drops" it off there as well. So, without taking the covers off, it is impossible to say what is causing it.
In the front of the motor, you got your cam seals, main (crank) seal, oil pump w/ gasgets, various inspection holes and some other stuff that could be leaking.
You can take the side covers off and try to see what is going on there. I do recomend, however, taking the crank pulley off and taking all covers off. Then, armed with a flashlight, you can really see what is going on there. Expose all the stuff there, clean it with love and let the car idle for a while and play with throttle. You will see where the leaking occurs.
Hope this helps.
Alex
Old Apr 21, 2004 | 07:13 PM
1WRX2NV's Avatar
Car Info: 02 STi
Perfect thanks Alex!!
Sorry I was told they were cam covers...from someone.... **cough**MIKE MPJ**cough** lol. I guess it's hard to explain things over the phone, when you can't actually see it.
thanks again
-freddie
ps. So this is something I can do at home...right alex?, no special tools or anything? I do all my installs, so I dont think it should be hard.
Old Apr 21, 2004 | 10:43 PM
thebankman's Avatar
Car Info: subaru
I had a similar oil leak problem with another car. A mechanic told me the valve cover and oil pan were leaking....turns out the valve cover's 4 bolts had to be tightened down. after cleaning off the engine it could be visually seen that nothing was leaking afterward, and the claim that the oil pan was leaking was wrong.
Check to make sure exactly what's the problem. Check all the places it could be or even the rare places it wouldn't seem possible a leak could come from. You may be suprised by what you find. Good luck!
Old Apr 22, 2004 | 05:01 PM
1WRX2NV's Avatar
Car Info: 02 STi
thanks thebankman,
Yeah I will clean it off, check the bolts....and go from there...before I start tearing it appart. If it does continue to leak at least I know what I can do further to fix it...
Thanks guys for all the info...
-freddie
Old Apr 22, 2004 | 06:18 PM
Imprezer's Avatar
Admin v2.0
Yeah, you can do it yourself.
Its like changing the underdrive crank pulley. You take it off and then you will have access to the timing belt cover (middle). The side ones come off easy, but you might need to remove the rad fans.
After that, put the pulley+access belts back on and idle the car and look...
Yeah, the valve cover could be leaking on the front too.
Once you do what I explained above, you will be able to tell what is wrong with it.
Of course, you can bring you car to me as well. I charge $899.95 per hour. But, I can do that with my eyes closed while two girls nibble on my ears.
Good luck...
- Alex
Old Apr 22, 2004 | 06:44 PM
1WRX2NV's Avatar
Car Info: 02 STi
Good luck...
- Alex
you mean Joe and Dan?? LOL
thanks Alex
-freddie
Krinkov
Feb 22, 2011 12:48 PM
wrxout
Oct 26, 2005 03:13 PM
imprazian168
Jun 11, 2004 02:09 AM
stocker
Nov 5, 2003 09:49 AM
minisiu
May 22, 2003 10:52 PM
