Boost only reads at .05 bars
Old Apr 27, 2004 | 03:52 PM
Lint WRX's Avatar
Car Info: 05 White STi
boost is pegging at .05 bars.. i have an mbc but whenever i turn up the boost the gauge will not read anything higher..... please help
Old Apr 27, 2004 | 11:37 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Are you sure you're not cranking it closed? 0.05 is around wastegate pressure. A quick test would be to unplug the hose leading out of the boost T...go BRIEFLY full throttle (dangerous if you sustain this AT ALL). If you make more boost...your MBC is messed up.
Another thing to check is that the plastic restrictor in the line is not melted shut.
Good luck, and ditch the MBC for something better.
Old Apr 28, 2004 | 03:29 PM
barrelroll_9's Avatar
Car Info: 2004 Subaru WRX (Silver Sedan)
The Accessport would work much better. I can tell you it rocks! :banana:
slvrsubywgn
Oct 25, 2005 04:52 PM
hYpE-R-29
Oct 18, 2004 09:20 AM
Impreza01
Aug 19, 2004 10:49 PM
SloshSparky
Jan 23, 2004 01:18 PM
Spool_up
Mar 25, 2003 10:41 PM
