Boost only gauge?
Old Feb 12, 2003 | 08:32 AM
Rapid_Roo's Avatar
Car Info: 03 WRX | 95 GC
Question Boost only gauge?
I was wondering, is it bad that I got a boost only gauge from Autometer.
I have noticed that most people get the boost/vacuum gauge vs the boost only gauge. Looking at the installation instruction the boost/vacuum gauge actually comes with the spliter (T) for the gauge install, whereas the boost only does not.
will I end up damaging the gauge? should I get the boost/vaccum one instead?
any help would be greatly appreciated. Thank you in advance.
Old Feb 12, 2003 | 02:42 PM
mmboost's Avatar
What's the part number?
I highly doubt you'll hurt anything.
Vacuum is what you see when you close the throttle. Boost is what you see when you open it.
jason
Old Feb 12, 2003 | 03:39 PM
Wingless Wonder's Avatar
Yes. Most of the time, the vacuum/boost gauge will indicate manifold vacuum. This includes idle, most cruise conditions, and deceleration. The turbo only produces boost with a significant throttle application under load (can't produce boost while car is stationary) and above a certain engine RPM, therefore the gauge will be boring to look at a great deal of the time.
^ww^
Old Feb 12, 2003 | 03:49 PM
mmboost's Avatar
It can't? I can make my boost meter go over 1 bar even at idle. Heh, my friends Supra can blow his BOV quite loudly while in neutral.
jason
Old Feb 12, 2003 | 04:03 PM
At idle? Are you using your finger to move the pointer?
He should stay away from re-fried beans.
^ww^
Old Feb 12, 2003 | 06:54 PM
Rapid_Roo's Avatar
ok other than look boring, will it hurt anything. I guess if it breaks I can just buy another one, this time the right one.
I just don't feel like returning it. I'm lazy. Hey any one know if its hard to return stuff to Summit Racing.com
Old Feb 12, 2003 | 11:41 PM
mmboost's Avatar
^ww^
OK make up our mind... "idle" or "stationary". I responded to "stationary". If I sit in my car, stationary in neutral I can stomp on the gas pedal and generate over 14.5 PSI on my boost meter (on both my boost meters ). I've seen it with my own peepers.
cdawg
Jan 4, 2008 03:44 PM
odzilla
Feb 13, 2004 08:18 AM
RallySubie
May 2, 2003 08:52 AM
mattr762
Apr 18, 2003 09:12 AM
