Blitz Recirculating BOV how-to
Old Jul 20, 2003 | 01:38 PM
boloheadrat's Avatar
I was bored yesterday, so I decided to convert my Blitz DD BOV to a 100% recirculating type. For those that don't know, the stock bypass valve works fine, this is just for those who want something different. First, I dissassembled the Blitz BOV and the stock valve:
Old Jul 20, 2003 | 01:40 PM
Two things need to be done. First the stock recirculating fitting needs to be ground flush to mate up to the Blitz unit. Here it is half way done:
Old Jul 20, 2003 | 01:45 PM
The second thing you need to do is rotate the blitz BOV about 135 degrees clockwise. The outlet of the bov should be parallel to the bottom left side of the mounting flange. Here is a bottom view of the flange with the new holes drilled and counter sunk:
Old Jul 20, 2003 | 01:47 PM
So far so good. You may need to file the holes in the stock recirculating fitting just a bit to get them to line up, otherwise everything should bolt together like this:
Old Jul 20, 2003 | 01:49 PM
Uhoh, it's getting dark, I better hurry before the monsters come out. Here is the modified BOV on the I/C:
Old Jul 20, 2003 | 01:51 PM
Old Jul 20, 2003 | 01:54 PM
Finally put it back in the car. I found it is easier to put the BOV in first, then the I/C, and finally put the two together. Have fun!
Old Jul 21, 2003 | 12:59 AM
mmboost's Avatar
So what's the difference in sound between the Blitz recirc and non-recirc and stock and blitz recirc?
jason
Old Jul 21, 2003 | 05:24 AM
jason
Stock recirculating and Blitz recirculating sound about the same... That is, you can't hear much.
Old Jul 21, 2003 | 10:14 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Old Jul 21, 2003 | 06:10 PM
BlkRx's Avatar
Car Info: 2004 Black Wrx
So you just wanted to see if you could do it? Doesnt blitz make a 50/50 bov?
Old Jul 21, 2003 | 06:11 PM
BlkRx's Avatar
Oh, i meant to say nice job too.
Old Jul 22, 2003 | 02:23 AM
Thanks. From what I know there is no Blitz 50/50 recirculation fitting. Actually, I was going to put the stock valve back on, but I wanted to see if I could still use the Blitz first. Function over form, but it's nice to have some bling bling.
strider327
Jun 22, 2010 08:24 AM
ViVaSuBy
Sep 26, 2007 03:30 PM
boloheadrat
Jul 20, 2003 05:59 PM
fatcatturbo
Feb 1, 2003 11:55 AM
Daios
15
Dec 13, 2002 04:56 PM
