Is MoRe BoOsT tHiS eAsY??
Old Jul 22, 2003 | 01:25 AM
bedweaselwrx's Avatar
Car Info: 2002 WRX
So I read this on Overboost.com in one of there tech articles, was wondering if it was true? and if it is something safe you could do on the 02-04 WRX/STI?
"Those of you running turbochargers, listen up! Many stock (and even tuning shop) configurations use a port on the compressor housing to provide a pressure reference to the wastegate. What this ends up meaning is that the wastegate sees a pressure signal that's a little higher than pressure at the intake manifold because of the pressure drop through the intercooler and its plumbing. By simply capping the compressor fitting and moving the wastegate signal line to the intake manifold, you can pick up a few more pounds of turbo boost and enjoy more responsive boost control." www.overboost.com
it sounds viable but I thought that I would check with some of you first to see what you thought.
Thanks..
Old Jul 22, 2003 | 02:56 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Yes you could do that, but the MAP sensor would override your settings I bet. The ECU controls all
Get a way to bypass the factory boost controller system, then we're talking.
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
yzercyber
Aug 12, 2005 03:42 PM
escaflowne
Mar 16, 2004 12:03 PM
sponaugle
May 17, 2003 06:32 PM
