Big install, how much boost fluid do I need?
Old Apr 14, 2005 | 01:33 PM
runnah's Avatar
Car Info: Grocery getter 02 wrx wagon Sexy Silver
not really but I need to know if I'm missing anything to swap turbos, and install down and up pipes.
I have:
up pipe gaskets both ends
down pipe gaskets both ends
turbo gaskets
2 CEL fixes
Is there anything I'm missing? (besides tools etc..)
Old Apr 14, 2005 | 02:29 PM
coolant and oil
Old Apr 14, 2005 | 10:06 PM
topnotchwrx's Avatar
From: Just when I find the key to success, someone goes and changes the locks.
Car Info: "Why Warthog sir?"
cant forget about them muffler bearings. and one of the most important things that people forget is hooking the flux capicator back up. i hope you have fun. i know i did.
Old Apr 15, 2005 | 06:27 AM
runnah's Avatar
I'll probly re-pack those at the same time. I just hope we don't get too drunk before we finish.
Old Apr 15, 2005 | 06:38 AM
Wingless Wonder's Avatar
Do you have the usual upgraded injectors and fuel pump to go with the new turbo? What are you doing for engine management?
Old Apr 15, 2005 | 07:54 AM
runnah's Avatar
not yet but I will down the line, I plan on getting a turbo xs utech.
Should I hold off until I get the injectors/pump and EM?
Old Apr 15, 2005 | 09:33 AM
mmboost's Avatar
Most definitely yes. Do it right the first time and just wait.
jason
Old Apr 15, 2005 | 10:25 AM
runnah's Avatar
jason
how bad would it be to do it anyways?
Old Apr 15, 2005 | 11:13 AM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
it could be very, very bad.....you will starve your engine of fuel, and could potentially burn up your piston rings, or even worse, throw a valve.....I would wait....because unless you drove your car like grandma, and stayed OUT of boost all the time.....you will need bigger injectors/ fuel pump.
-Ted
Old Apr 15, 2005 | 12:08 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
yea, injectors and fuel pump are a must. Oh and when i did my install i lost a lot of coolant so when you get it started back up, you should bleed your coolant lines if you lost a lot of coolant in the process of changing your turbo to eliminate the air bubbles in your coolant lines. And you should also upgrade your spark plugs NGK iridiums are a good choice.
Old Apr 15, 2005 | 12:14 PM
runnah's Avatar
-Ted
I was told as long as I turn the boost to around 13psi I should be fine.
But im a total greenie when it comes to stuff like this.
BTW its a stock sti vf-39 turbo, if that makes a difference.
JMeltzer4
Aug 17, 2010 07:23 PM
jinorazi
May 22, 2008 04:52 PM
jasno999
Feb 9, 2004 04:49 PM
qwk_wrx
Jan 15, 2004 05:42 PM
addictarmy
Sep 24, 2003 11:47 AM
