Best RPM to shift?
Old May 24, 2003 | 06:44 PM
mario's Avatar
Smile
i shift about 7200 rpms in 1,2,3 then 4th at 6800 rpms but w/ a mostly stock rex there should be no need to go to 4.
have fun drive safe
mario
Old May 25, 2003 | 03:08 AM
mario's Avatar
Thumbs up
hey there Uncle Dan i liked ur web site. it was interesting if u wouldn't mind could u send me some tips and pics on how u installed your dual staged boost controller.
thank you
mario
Old Jun 4, 2003 | 09:07 AM
DarriiffftaaHuy's Avatar
well for my fastest run of 135 mph, i went past 7 up through 3rd and shifted at like 6500 in 4th - 5th gear, then the car began to pull again. but you will notice the rpms struggling to move up in 4th gear and the speed also struggling... by shifting into 5th you are put back in your powerband and it just climbs!
Old Jun 4, 2003 | 01:46 PM
mmboost's Avatar
Shifting at peak power is skydiving with huge helium balloons.
...think of a horsepower curve from a dyno chart for your car. OK, got the image in your head? Power bands in drag racing is all about continuously keeping the engine in a state where its getting the highest possible area under that curve.
Shifting early - you have too much low RPM power production. Less torque, less horsepower, less accelleration. You might as well be in an OZ Rally Lancer.
Shifting late - you have a very similar problem, but now you're also wasting engery via wasted RPMs and you take the chance of hitting fuel cut (for those w/o an a defenser).
So what's shifting just right? You want to make sure that your shifts containt as much as the top of your power band as possible... highest area under the curve. On my mildly modified WRX this means about what someone else said, "7200". And I've proven this. The difference between shifting at redline and 7200 got me almost 0.3 seconds consistently. You want to go THRU your peak.
Getting your car dyno'd is a great way to figure out exact shift points. Even better is to get datalogging to see how your RPMs drop from gear to gear depending on when you shift. Just from perfecting shift points you can gain from 1/4 to over 1 full second.
jason
Flame30689
Sep 22, 2008 10:16 AM
2point5AWD
Jul 1, 2006 07:19 PM
SinisterWRX
Sep 17, 2003 07:02 PM
SubySal
Jul 13, 2003 09:14 PM
StankFootZ
Jan 3, 2003 12:24 PM
