best performance upgrade for a 2004 wrx
Old Feb 3, 2004 | 07:46 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
i'd flash after you get some parts. that way you don't have to go tune it again.
Old Feb 4, 2004 | 03:05 PM
4CEDAWD's Avatar
Car Info: 2.2L WITH STAGE 2 FORCED INDUCTION
actually i was thinking of doing the up and down pipe first. along with the exhaust system. i was told by my tuner that it would be a substantial increase to do these three at once. also , anyone take the silencer out of their intake yet? any noticeable difference? i was also told about aftermarket headers because an o4's are so restrictive.. any truth to that??
thanks and good hunting,
todd
Old Feb 5, 2004 | 11:43 PM
4CEDAWD's Avatar
u ever figure out what caused the tranny problems?? just currious.
thanks in advance, todd
Old Feb 6, 2004 | 09:25 AM
DizzyWRX's Avatar
Originally posted by hashiriya
Best 1st mod: Start saving for a 6MT
That'd be a very expensive first mod.
Old Feb 6, 2004 | 09:30 AM
4CEDAWD's Avatar
yes ,but i am sure it would be worht it!!
Old Feb 6, 2004 | 02:09 PM
ilivas's Avatar
get a turbo xs utec and stay off nasioc forums. They will mislead you.
Old Feb 6, 2004 | 03:52 PM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
Boost control. I have the apexi avc-r electronic one, works awsome and gives me around 20 hp. a downpipe and catback will give you about 30 hp as well
Old Feb 6, 2004 | 10:26 PM
Bankie's Avatar
Car Info: 2004 Java Black WRX Wagon
Originally posted by ilivas
I meant to say there is no harmonic damper on an after market crank pulley.
The stock crank pulley doesn't have one either.
You don't want to do that on the 04s. You'll get PTFB and with the open-closed loop delay on the 04 ecu you'll get very high EGTs.
First power mods: Uppipe, Downpipe, IC Hoses, Engine Management, Axle/Cat-Back, Lightened (not underdriven) Pulley.
First suspension mods: Tires, Rear sway bar, Endlinks, Springs.
Old Feb 7, 2004 | 01:39 PM
Cyrus923's Avatar
Dont seem to have any problems with running 16 psi on the electronic boost control on the 04 so Im not sure what your talking about. Many people have ran them on 04's without any problems and when only running +2 psi, 1 under cutoff, I think I will be just fine
Old Feb 7, 2004 | 02:40 PM
Bankie's Avatar
Are you monitoring your EGTs? High EGTs won't normally kill your engine out right but they can reduce the engine's longevity. On the 04s you really should monitor your EGTs if you have a boost controller. The best option is a reflash/utec if you want to alter boost levels, IMO.
Old Jun 3, 2004 | 04:07 AM
WRandX's Avatar
so its been a long while since the 04s been out. I'm new and thinking i'll be getting a WRX 04. I've search but its hard to research because you can't just search results for "04". My question is whats with the ECU and upgraded turbos, uppipes, downpipes, catless exhaust? CEL fixes? From what i've been reading MBCs/EBCs are a NO for 2004s.
Old Jun 4, 2004 | 01:08 AM
DJTEN4's Avatar
Car Info: 03 yellow wrx
first mods, i vote intake and bov
jk, go up/dp, i think helix it good quality and cheap... they are good stuff, i also liked the headers, but its all up to personal prefference
Old Jun 4, 2004 | 10:09 AM
scoobykid04's Avatar
Car Info: 04 SUBARU WRX SEDAN
I got my 04 scooby last july, i love the car to death, upgrades i did in order, hks bov, hks intake, gfb pulley kit, hks up-pipe, down pipe and tanabe racing med cat back, then a apexi s-afc 2 kinda fell into my hands so thats in the car now also...and dont forget the turbo timer...
Old Jun 4, 2004 | 10:24 AM
bluebayou's Avatar
Car Info: 2011 STi wagon
Originally Posted by hashiriya
Which would only beg the post: "What's the best mod for an STi?".
an "undo" button on the dash which you can press as soon as you see flashing lights behind you?
