Bellmouth or divorced wastegate DP?
Old Nov 22, 2004 | 05:32 PM
imPreZzdis*sti*'s Avatar
Car Info: '05 crystalgrey sti
Just wondering what scooby tuners prefer for better end results. A bellmouth or divorced wastegate down pipe?
Old Nov 23, 2004 | 01:35 AM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
I have a helix bellmouth and am satisfied with it.
You will see a trend, just about 7/8 of the manufacturers of downpipes go with a large bellmouth while the other 1/8 goes with the divorced wastegate. It depends on the tuners you talk to, if you go to Vishnu they make a divorceced wastegate formation because of flow pattern. Others go with the bellmouth because of backpressure issues that tend to follow (while not much) with the divorced wastegate.
Do some research on the subject.
www.cobbtuning.com
www.vishnutuning.com
www.subarureview.com
Good Luck
Rush
Old Nov 23, 2004 | 10:46 AM
I was actually gonna get the Helix DP until I started to research a little more about pipes with a divorced wastegate like the perrin and the vishnu. I think in when Im ready I'll still end up with a bellmouth. Thanks For the suggestion.
Old Nov 23, 2004 | 11:32 AM
hockeygod's Avatar
Car Info: 2004 WRB WRX
I think Vishnu uses a bellmouth for the sti but divorced for the WRX. Might want to check with them. Also in my opinion anytime a tuner that dyno tunes their products are going to be able to back up their claims better than companies that just produce them.
Old Dec 29, 2004 | 03:15 PM
DKS_Subaru's Avatar
it all depends on what turbo you want to get...if you are getting a vf series i would get the divorced, my bellmouth and full catless allows for mad boost creep...still combating the problem...good luck
Old Jan 6, 2005 | 03:38 PM
apssti's Avatar
anything but HKS.
Old Jan 6, 2005 | 07:40 PM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
bellmouth if money is an issue but if not go with the other. I have a bellmouth and have some boost creep issues as well
tohsh
May 24, 2010 11:47 PM
IsleScoob
Hawaii Classifieds
May 12, 2009 12:20 PM
A170123W
Jun 19, 2007 03:35 PM
PurduePhiGam
Nov 26, 2005 01:29 AM
Boost Addict
Jul 9, 2005 08:14 PM
