Bad EGT sensor?
Old Nov 8, 2004 | 08:17 AM
SilverRex04's Avatar
Car Info: 04 Sti swap, VF22 18psi, 255l fule pump,ecutek 93 oct, Full exhaust TXS, Sti ra gears, much more...
Bad EGT sensor?
I keep getting the code for "EGT High Bank" I think its 546. Anyway that would be the reason the car keeps pulling timeing right? Thanks. Tom
Old Nov 8, 2004 | 09:46 AM
mmboost's Avatar
WRX ECUs pull timing when they sense knock. If your car is pulling timing it is because you are knocking. EGTs are only used to check for proper exhaust temperature for activating the catalytic converters. As for the EGT code, your censor or its wiring has probably gone bad.
jason
A.V.E.
Apr 14, 2011 07:49 PM
stets
Hawaii Classifieds
17
Jan 17, 2011 07:24 PM
spdkills
Jan 25, 2003 03:48 PM
zeke79
Jan 22, 2003 08:54 AM
