Bad Coil caused burned up Piston?!?
Old Nov 5, 2003 | 09:07 AM
mmboost's Avatar
Flashing CEL means misfire. It happens when misfiring happens and then (hopefully) the remaining, solid CEL indicates the exact problem.
As for reprogramming the ECU, that sounds really stupid. I dunno what those TX guys were thinking. They didn't give you anymore info?
To me, what the NH guys are saying sounds totally plausible. The cause of the misfire and the results from misfire will precipitate all sorts of other issues that can wreck other parts involved in the process... like valves, pistons and rings.
jason
Old Nov 5, 2003 | 11:28 AM
andyhidley's Avatar
Car Info: 2002 WRX
There are two types of CEL iluminations. They are flashing and the other is steady on.
Sorry I dont recall which is which. But one means "engine problem, get it fixed as soon as possible" the other means "major problem, shut off engine"
I think I saw this in the owners manual of my WRX or maybe a RS or lastly the factory service manual. Check your owners manual.
Old Nov 5, 2003 | 07:54 PM
Uncle Scotty's Avatar
Whatever happens, if it gets covered under warranty, be happy.
Many have been denied warranty work for no good reason, and it sounds like the dealer will take care of your problem properly.
A bit of inconvenience and small expense for a good outcome is much better than not.
Old Nov 5, 2003 | 08:22 PM
awns729's Avatar
Car Info: want a WRX
a rat got under the hood of my moms highlander, chewed up 2 spark plug wires. they didnt say anything was wrong with the engine but they did say the ecu got short circuted...so they replaced that and the wires...we were out 300$, insurance picked up the rest...she only drove like 30 miles before taking it to the dealer....just thought id share
Old Nov 22, 2003 | 03:54 AM
DarkAngel's Avatar
wow I had the same problem but they just changed the coil pack. and it runs fine but I wonder if there are other problems
Old Nov 22, 2003 | 11:12 AM
international B's Avatar
Chewwwwy
check your compression, you will find out!
Glad to hear that the work is being done under warranty!
Old Nov 22, 2003 | 10:04 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
w3rd. although there really should be no question that they should replace your engine, many before you have been told that they will have to pay for it out of their own pocket because they were abusing their cars. you got lucky as far as dealer choice IMO. some dealers can turn your life into hell in no time flat.
edzwrx
May 17, 2012 12:17 AM
cuscogdb
May 10, 2012 02:56 PM
RavSpec
13
Oct 6, 2008 12:39 PM
cmlnr
Apr 30, 2005 07:53 AM
Teddy
Aug 7, 2004 12:35 PM
