Any way to swap out the stock boost guage ?
Old Feb 1, 2003 | 11:03 AM
Porkchop-WRX's Avatar
Car Info: Silver WRX
I was wondering if you can swap out the stock MPA guage for a guage that measures in PSI instead?
Has anyone ever don this or looked in to it?
thanks in advance
Old Feb 1, 2003 | 11:07 AM
Zoeb2s's Avatar
I <3 White Girls
im sure you can do it, but you would have to find a very small boost gauge...most gauges are 52mm or 60 mm...the stock one is like 40mm(not an exact measurement, just an estimate)
Old Feb 9, 2003 | 11:54 AM
Dew-Subaru's Avatar
Car Info: WRX 2002 sedan
Hey man did you find a replacement for the stock gauge yet?
Iam trying to find one also . I need a psi one so i can read it better, since now that I have a EBC.
thanks Dew-subaru
Old Feb 9, 2003 | 02:12 PM
nqwan's Avatar
Car Info: o2 duburu arr exu
omori makes a 45mm boost gauge in psi and hks makes 46mm gauges but the boost reads in kpa/bar.
granted both are slightly bigger than stock, you should be able to fit them in with a bit of muscle since the housing is rubber
(referring to the column mounted boost gauge).
Old Feb 10, 2003 | 05:08 PM
I still am looking for one but maybe someone can give me a exact measurement of the stock guage. Maybe from a dealer or some one of that nature.
Old Feb 11, 2003 | 08:05 AM
ride5000's Avatar
if you're going to go so far as to remove stock, why don't you take it apart and see if you can recalibrate the face so that psi numbers are legible?
the gauge itself will be exactly the same--the scale on which it is read will be different, and that's all.
hth
ken
Funks
Feb 5, 2014 10:32 PM
freshrex
Aug 25, 2008 01:59 AM
JRsWRX
Mar 13, 2006 03:56 PM
rebbaz
Jan 22, 2005 08:52 PM
andyC
Mar 31, 2003 09:18 PM
