Air filter question (reuseables good or bad?)
Old Jul 27, 2005 | 06:50 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
Air filter quesiton
it is time for me to change my filter. is there an air filter that is reusable like the k&n but does not require oil? I heard that paper filters are better than the oil'd up ones because the oiled filters sometimes leave a residue on the MAF sensor. Or is there nothing to worry about the k&n panel filter?.
Old Jul 27, 2005 | 06:56 PM
Peaty's Avatar
http://www.scoobymods.com/forums/showthread.php?t=2271
If you oil a filter properly and then let it sit on a shop towel overnight you should have no MAF problems. I've been using that style of filter for years w/ no issues. I like the green filter better than the K&N myself.
Old Jul 27, 2005 | 10:32 PM
thanks for the tip.
Old Jul 30, 2005 | 12:22 AM
Choku Dori's Avatar
Car Info: Corvette Z51
Lil' Ryan, think about a Blitz panel filter. I'm gonna get one when my my stocker craps out
Old Jul 30, 2005 | 08:50 AM
meilers's Avatar
I think the oil-on-MAF issue is overhyped. I used the Perrin Foam filter for 20,000 miles (washing and oiling with every oil change) before I pulled my MAF sensor and looked at it; there was a little bit of dust buildup but no visible oil or sludge on the sensor. I agree with Peaty's suggestion of letting the filter sit and the oil settle; another tip is to make certain the filter is 100% dry before you spray the oil on.
Old Jul 30, 2005 | 10:45 PM
Boost Addict's Avatar
I personally have run K&N panel filters on every car I've owned and never a prob.
I just wash, let it sit in the sun(make sure its compeltely dry), reoil it and let it sit for a solid hour... then for good measure, If drop the filter onto a towel 2 or 3 times on each side to drop any beaded oil or any excess oil trapped between the actual filter fibers and the metal mesh... just shake things up a bit, get any loose oil off... and its ready to go...
Now if you are a bit paranoid about it... then take the extra step to make sure you have no doubt or worry in your mind, I personally liked the suggestion of leaving it on a shop towel over night... personally, I drive a lot, and am rarely sitting my car... so if thats your case, then id keep the stock filter for days like this... just pop it in for any trips you may need to make... and then the next day replace it with your oiled one
Hope this helped
Vimik
Old Jul 31, 2005 | 07:17 AM
Wingless Wonder's Avatar
I prefer OEM paper filters over any oiled element. I've used K&N filters in the past on other cars and I like the idea of a reuseable element but in actual use I found the cleaning and re-oiling process to be a chore. I think the K&N works fine if properly cleaned and oiled.
I also like the OEM filter because I believe it is less restrictive than the K&N. On Vishnu's old site pages, there was a reference to back to back dyno runs comparing the OEM and K&N reuseable, and the K&N lost 2 to 3 horsepower at higher RPM. The OEM has many, many more pleats which greatly increases filtering surface area for less restriction. At the time, Vishnu Performance decided not to offer K&N filters for sale along with their other upgrades.
Maybe some dyno-equipped shop would like to do another back-to-back test under controlled conditions to see if this still holds true. I know that every dyno has a margin of error and very small differences in power should be considered a run-to-run variance.
Old Aug 1, 2005 | 09:51 AM
yayitzian's Avatar
Hurray, it's Ian!!
Car Info: 2002 MBP WRX Sedan
me too. i've been using the Green Filter for about 3 years now. no problems.
Old Aug 1, 2005 | 12:11 PM
meilers's Avatar
I didn't switch to an oiled filter because of increased airflow; no one can detect the minimal HP increase (2-3 hp, max) such a filter would give you without tuning as part of your filter install. The reason I switched was because the OEM filters, although they are cheap and do flow well, kept coming out CLEAN! After 3k miles the filters looked nearly new, which is a problem -- I wanted them to be BLACK with gunk they cleaned out of my intake charge.
When I switched to the Perrin oiled foam panel filter, I definitely picked up more gunk and finer particles. Here in Arizona our air is full of extremely fine dust and talcum-power-size sand, as well as tons of brake dust (we never get rain to wash this stuff out of the air or off the road). The Perrin filter shows visible discoloring after just 2k miles and by 3k miles it is nearly black in the center and overall quite dirty; I also see tiny bits of stuff like bird down, pollen, flower petals and other kinds of junk collect on it. Anything to keep this stuff out of your engine is good!
Old Aug 2, 2005 | 04:33 AM
I agree with meilers... truth is... The Dyno testing that Vishnu did was on new filter vs new filter... K&N operates BETTER when its dirty in comparison to the stock filter... Clean VS Clean, the difference is miniscule... So on your way to 3,000 miles, you will have better airflow with a K&N or in meilers case a Perrin... because these filters are set out to COLLECT more gunk and keep our engines healthier, and allow our intake systems to breath happier even when dirty, as opposed to the congestion they will experience when the stock element is dirty...
Vimik
Old Aug 2, 2005 | 09:13 AM
yayitzian's Avatar
Hurray, it's Ian!!
i switched to the green filter because I goto school in riverside (with Winding Road). We have the 1st most polluted county tied with LA. we get their smog, and our mountains trap it. plus there is a lot of dust too. plus i'm REALLY glad i had it when we had all those fires and that ash was floating around for days. also, I did it so i'd never have to buy a new one. cleaning and re-oiling is more convinient.
Old Aug 2, 2005 | 10:40 AM
Peaty's Avatar
I've had an oil analysis done twice now and it shows that the Green Filter is working just as well as paper. My Si levels are in one case below the average and in the other about average.
Old Aug 2, 2005 | 01:44 PM
i like paper because the other styles dont get cleaned enough
if you need an air filter hit me up i have the short ram because of the FMIC so i have a bunch of airfilters that are new
Choku Dori
Jul 6, 2010 07:02 PM
96Imprez
Mar 5, 2008 08:31 AM
se0ul
Jun 2, 2005 01:59 AM
Peaty
Aug 20, 2003 07:01 PM
