2005 WRX stalls when put in clutch.
Old Apr 30, 2010 | 08:11 AM
prlbluwrx's Avatar
Car Info: 2015 WRX
I cant figure out my my WRX stalls it does it only like 3-4 times a week. I will be in traffic or just running around town. I put the clutch in to down shift and the rpm's just fall all the way off. sometimes the RPM's will hit 0 then bounce back up but most of the time i have to restart the car. I have no idea whats going on. Anyone got any ideas.
Old Apr 30, 2010 | 08:49 AM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
any mods done to it? if not look for vacuum leaks
Old Apr 30, 2010 | 09:38 AM
prlbluwrx's Avatar
Car Info: 2015 WRX
I have up and down pipe catless, access port stage 2, intake. I have had the car check in two shops for vac leaks and they found nothing. This boggles my mind.
Old May 20, 2010 | 11:36 AM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
I came across the same problem and I'm running a catless dp only. Since you have an access port on stg2 it might be the intake that is causing the problem. Most like a Protune and a good maintenance should do the trick. (I think, hope that helps)
Old May 21, 2010 | 05:36 AM
WRX409's Avatar
Car Info: 04 WRX
It could be your IAC valve is faulty,you have a vacuum leak,
or your car needs to be tuned.
If anything that intake is leaning your car out without being
properly tuned.
Old May 12, 2017 | 10:34 PM
Morgan Smith's Avatar
Car Info: 2003 Subaru WRX
Old thread, but only one I've seen that relates to my problem
I've had my 2003 WRX for a few months now, it was misfiring for a bit so I changed the coil packs and plugs a few days ago (desperately needed done, 162k miles) and today it did the same thing as your 05. When cruising sometimes when I'd clutch to downshift or stop, it would die, other times it would barely save itself. I'm getting a little worried and was just wondering if any of you ever found a fix or isolated the problem. Thanks much!
prlbluwrx
Aug 3, 2011 07:50 PM
stubz203
Mar 19, 2007 07:31 PM
Striker6502
May 13, 2004 04:18 PM
wickedwrx02
Oct 7, 2003 02:57 PM
Impreza_WRX_STi
Jul 4, 2003 01:34 PM
