'04 WRX noises
Old Nov 1, 2004 | 04:27 PM
grycoleman's Avatar
Car Info: 04 WRX 5dr
'04 WRX noises
so today this kook in his ION wasn't letting me in so i had to smoke him. when i did i heard this rattle or grind or maybe a crunch. this has happened before but it's starting to worry me. it only happens under heavy acceleration especially when i drop into 2nd or 3rd. has anyone else had this happen. i know boxer engines are quirky but i want to be sure. here's the facts:
MY04 WRX 5 door 24,000 miles
Automatic trans
Pulley kit
drop in filter
any help as always greatly appreciated
Old Nov 1, 2004 | 06:20 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Did it sound like bb's falling into a tin can?
Old Nov 2, 2004 | 07:36 AM
grycoleman's Avatar
yeah kind of. what is it?
Old Nov 2, 2004 | 10:48 AM
MO REX's Avatar
If it does sound like that it is most likely detonation (knock) and if it is loud enough for you to hear thats not good. You need to take it easy on the car untill you have it checked out and fixed so you dont toast your engine. Here is a link to a Yahoo search on detonation http://search.yahoo.com/search?p=det...t-173&toggle=1.
Have you changed the plugs or done anything else to the car right before this started to happen?
Old Nov 2, 2004 | 12:36 PM
grycoleman's Avatar
so is that all it could be? anything else? no the engine is totally stock except for the pulleys and the K&N drop in.
Old Nov 2, 2004 | 02:54 PM
mmboost's Avatar
you might have a dirty fuel filter that's starving the injectors. not enough fuel gets to the injectors fast enough when you punch it like that.
jason
Old Nov 2, 2004 | 10:57 PM
RussB's Avatar
Car Info: $200,000 sports car
wastegate flutter maybe? is it coming from the passenger side of the car, almost like it's under the dash?
when accelerating to pass in an automatic, the engine is not under as high of a load as in a 5 speed. the auto kicks down to 2nd or 3rd as the original poster said. i used to get really bad WG flutter with my stock turbo.
this last idea is way off in left field, but it could be this: http://www.scoobymods.com/forums/showthread.php?t=1205
my dash used to rattle very bad when the engine was revving high, after doing this mod it went away.
Old Nov 3, 2004 | 07:58 AM
grycoleman's Avatar
it's definatly not the dash. it's almost like an amplified crunch that the AT makes when down shifting. it doesn't sound like its on the right side. it's going in tommorow ilet you know
Old Nov 4, 2004 | 11:58 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Does it happen when you go WOT or at part throttle? If WOT, then its likely detonation, if partial throttle, I'd say wastegate flutter.
-- Ed
Old Nov 4, 2004 | 11:59 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Read this thread: https://www.i-club.com/forums/bay-area-15/crazy-wastegate-fluttering-76894/
to figure out if its wastegate flutter and how to fix it. You could also try the procedure to rule WG flutter out as a problem.
-- Ed
Old Nov 8, 2004 | 12:20 AM
percula's Avatar
Car Info: 06 STI, 00 LGT-L
hey i get that " bb's in a can sound " when i accelerate full throttle. All i have is a stromung axle back, only noticed the sound once i put this exhaust on.. thought it was the exhaust... now i'm getting worried...
04 wrx with 9300 miles
Old Nov 8, 2004 | 10:25 PM
percula's Avatar
any ideas why it pings? it's basically a new car
Old Nov 9, 2004 | 07:28 PM
grycoleman's Avatar
you may need a reflash. for me it turned out to be the gas. i was running chevron's premium when this noise started and i was told to switch to union 76 premium. tech says WRX's like this gas better. no more sounds so far
foeshaz
Dec 9, 2004 05:37 AM
StlWrx
May 11, 2003 04:29 PM
akordun
Mar 23, 2003 05:42 PM
2000RS
Feb 1, 2003 02:40 AM
Top
