02 wrx engine swap
Old Mar 22, 2004 | 10:55 AM
yamaha1995's Avatar
02 wrx engine swap
i own a 02 wrx and i am looking at a 03 wrx engine and trans on ebay! what would i need to swap engines and trans in my car. it comes with the ecu, and whole engine. could i just put the 03 engine in and the ecu. would the ecu work with the wiring harness? thanks a lot guys and gals
Old Mar 22, 2004 | 01:08 PM
02wrbluewrx's Avatar
Car Info: 2002 WR Blue WRX
Why would you want to swap they are the same engine?
Old Mar 22, 2004 | 01:19 PM
yamaha1995's Avatar
my 02 engine is a piece of sh*t! dont want to rebuild it.
DizzyWRX's Avatar
If there's nothing wrong with your 02 engine, then it's a waste of money IMO.
Old Mar 22, 2004 | 01:29 PM
well if you really think that its worth replacing then all you have to do is take one out and put the other in and reconnect everything...
Old Mar 22, 2004 | 03:43 PM
Need4Boost's Avatar
Car Info: GDA w/ RA-C & TO4E
It's a direct on in swap.
I take it you blew your 02 motor?
Old Mar 22, 2004 | 03:49 PM
yamaha1995's Avatar
yes i did, a couple times. just want to sell now! so figured this would be the easiest for me and most cost effective! i can put the motor in myself, i just am not confident in my abilities to rebuild it myself, already tried that and worked for a little bit, and something happened. its being diagnosed right now!
Old Mar 22, 2004 | 07:17 PM
awns729's Avatar
Car Info: want a WRX
It just seems like a waste to not upgrade to something better though!
Old Mar 22, 2004 | 07:21 PM
yamaha1995's Avatar
i dont want the car anymore, so its not really a waste to me!
Old Mar 23, 2004 | 08:16 AM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
This has most likely been asked, but would an sti motor and trans and ecu be a direct drop in for my 02 wrx? Would the sti trans bolt directly up to my 02 motor? What else would be involved in these if anything?
Old Mar 23, 2004 | 09:10 AM
I have heard you need a new driveshaft and rear diff......just what I have heard
MisterSheep
May 5, 2016 08:11 AM
PacificLegacy
Aug 26, 2014 09:54 PM
joltdudeuc
Oct 2, 2012 09:51 AM
gillz
Aug 21, 2011 10:21 PM
ch0g
Aug 27, 2006 06:14 PM
