~8 PSI of boost only?
Old May 6, 2007 | 05:11 PM
powerlogix's Avatar
Car Info: 2002 wrb WRX
I have a problem. I recently picked up a defi boost gauge and AP 2.0 and went to install it. I never had a boost gauge before so I installed it, it was reading around 8 PSI max and stuck there through out all gears at WOT.
I had an AEM intake so i did take it off and put a stock one back on, did a reflash to stage 1 and same issue. I also read it off AP readings and it was maxing out at around 7.92 psi. I'm not sure whats wrong exactly. Before this I did take it to the track a few times with times of 14.6-14.8. Just reflashed so wonder if i should wait for it to learn, but not sure if thats the case
2002 wrx
perrin uppipe
hks exhaust
cobb stage 1
let me know what you guys think, now i wonder if i was always at 8psi since i bought the car almost 2 years ago, never had a boost gauge to check until now.
car came with aem cai and uppipe. i added hki hi power and put a stock intake box back on.
Old May 7, 2007 | 02:14 AM
vietpunk916's Avatar
Car Info: AP1 S2k
Check the vaccume lines to the boost gauge and on. There might be a leak. Take off the clamps or whatever you used for the hoses and zip tie it just to check out if it's the problem. Most likely a boost leak.
Old May 7, 2007 | 09:41 AM
powerlogix's Avatar
checked all lines everything seems fine. i adjusted the wastegate a little bit and it went up to 10 psi. afterward i adjusted it again and was hitting almost 15psi and decided to stop there. But after a few runs now its back down to ~12-13psi max.
Old May 8, 2007 | 11:59 PM
powerlogix's Avatar
RESTRICTOR PILL MISSING!!!
Fixed the problem, then adjusted the wastegate since it was boosting too high.
y2Ldude
Mar 27, 2009 01:59 PM
tkarabian
Nov 10, 2006 12:17 AM
atom945
16
Nov 24, 2005 08:47 AM
carletto
16
Dec 5, 2004 10:07 AM
fongsaiyuk
Sep 5, 2003 03:51 PM
