Utec check engine light flash
Old Jul 27, 2003 | 02:57 PM
davenow's Avatar
its not flashing becasue you have a CEL.
Read your maual before you destroy your engine!
The UTEC flashes the CEL when it detects KNOCK!!
Its a knock light. You are knocking when you push your car. You need to grab a laptop and do some tuning to get rid of it or you are going to damage your engine. There is a reason they have a manual, you need to read it.
The boost is SUPPOSED TO taper at redline. 10-12 PSI at redline is exactly what it should be on the stock turbo.
I would blame the knock on that 16pSI peak. Or it could be timing realated, or fueling related. Read up and learn how to use your UTEC or sell it because its gonna cost you A LOT in the long run. If you are unwilling(are you?) or unable, you should sell it for a reflash, which requires no end user tuning. Same power but safer for those who dont know how or are unwilling to tune it themselves. The UTEC is MUCH more feature loaded than a reflash, but it really sounds like the wrong system for you
Old Jul 27, 2003 | 03:02 PM
ish's Avatar
ish
yeah, when your cel flashes it means your engine is knocking.
you need to tune that thing so it doesn't do that, knock is bad for your engine and you need to do something to fix that. as davenow said, read the manual. i would suggest paying someone to tune it for you, it will save you money in the long run
Old Jul 28, 2003 | 03:58 AM
davenow's Avatar
yes you are ABLE to, that doesnt mean that you SHOULD
16PSI at redline is VERY far out of the stock turbos efficiency range
As far as the UTEC goes, it can run whatever you want. Just set it to the boost level you want.
FYI, the stock turbo maxes out at 17PSI peak and about 13PSI at redline. Any higher than that and its out of its range and you are just making hot air
stg2lgcy00
Aug 3, 2007 07:28 PM
X-Factor
Sep 8, 2005 06:58 PM
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
1/500yellowwrx
Feb 15, 2004 03:18 PM
