uppipe advice welcome
Old Apr 15, 2003 | 09:28 PM
mario's Avatar
go to scoobmods.com then go to modifications and then go to 02-03wrx and then performance and then it should be on the first page called perrin uppipe install intructions its all the same uppipes are uppipes but i recommend a partner to help u out and wd40 spray all bolts and anything that your taking off (on the exhaust components that is ) have fun if u have any ?'s email me on thurs on
Old Apr 16, 2003 | 07:33 AM
Northrn Snowman's Avatar
Car Info: WRX SW 02
Go to:
http://www.vishnu-performance.com/downloads.htm
and download the up-pipe file. Everything is in there
Beware that this is rather sophisticated job. Took me about 8 hours.
Good luck
Old Apr 16, 2003 | 10:28 PM
4080wrx's Avatar
I just put my up and down pipe on this weekend. It took just over five hours. Go from underneath to remove the up pipe I recommend you use the PDE up pipe better quality than others. If you follow the PDE instructions you should not have a problem. You might want to get a socket wrench with a swivel head this will help with the tight areas also its a good idea to have a torque wrench.
4080
snowflow
Oct 25, 2010 12:50 AM
lastlaugh
Jun 27, 2005 06:14 PM
Slack
Apr 18, 2005 04:29 PM
gman03wrx
Sep 7, 2003 04:15 PM
(==ImPrEzAWR==)
Jul 7, 2003 12:03 PM
