update: VISHNU STAGE II
Old Jul 17, 2003 | 09:44 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Not too shabby Although maybe it's weather related but your MPH seems down compared to other Stage 2 owners. MPH is a good indicator of HP levels.
Old Jul 18, 2003 | 09:56 AM
teiva-boy's Avatar
For starters each .1 sec off of your 60' time is almost 2/10th's off your overall ET. So if you were hitting 1.7-1.8 you could have been getting 13.3-13.5.
Now as far as what gear your in, I swear when I was on the stock turbo I'd be at the top of third at the end of the 1/4 mile run. When I switched to a larger turbo, I had to start shifting into 4th. My shift points were roughly 1st(7000), 2nd(7000), 3rd(6800).
Many of the other VF30 guys that I know of are in the 12 sec range and trap at around 104-107.
By breaking into the 100+MPH range you've got some power on tap. But your times are not showing it I was hitting 13.5@99 on the stock turbo.
Old Jul 18, 2003 | 10:47 AM
teiva-boy's Avatar
A VF22 isn't exactly a stage II Eitherway, a VF22 is the largest of the IHI turbo's and you should be going even faster.
Old Jul 26, 2003 | 12:52 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
**hijack**
Jose,
Sorry to contact you so late, but the deal went through smoothly and I received the stock ecu.
Thank you and good luck!
Chris
Old Aug 5, 2003 | 12:18 AM
Christian's Avatar
Car Info: 03' WRB
2.0 60' times r not too good. sounds like your bogging off the line or something because of your trap and your 60'.
Old Aug 6, 2003 | 09:11 PM
teiva-boy's Avatar
Bogging off the line means nothing in your overall trap speed. I could get a 2.6sec 60' and my trap speeds are generally the same 97+.
The problem here, is one or more of the following...
Improper shifting
poor track
bad weather
bad tuning
Old Aug 8, 2003 | 11:15 PM
Christian's Avatar
Car Info: 03' WRB
if your bogging of the line its going to significantly increase your 60' times. and since you have less time to get to the end of the 1320 its going to mean your chances of hitting a higher trap speed. in others words a smoother launch will get you faster times.
gdogg
Sep 12, 2005 09:28 PM
KTW
Jul 12, 2004 07:33 PM
Cend_wrx
Apr 5, 2003 12:03 AM
mattr762
Mar 26, 2003 11:47 AM
David@VISHNU
Dec 10, 2002 07:40 PM
