Turbo Timer ?'s (any problems with alarm or remote?)
Old 01-24-2009, 02:16 AM
GripItUp's Avatar
Car Info: 2007 WRX Tr
Red face Turbo Timer ?'s (any problems with alarm or remote?)
I was just wondering if there are any electrical problems after installing a turbo timer, for example with the alarm or remote key. I just want to make sure before I purchase a Blitz DTT for my 07 TR. Thanks.
GripItUp is offline
Old 02-03-2009, 09:50 AM
Cp3aight's Avatar
Car Info: 05 WRX wagon
I have a problem where sometimes my shock sensor will be set off by the exhaust rattling and in order to get the alarm to work you have to tap the e-brake wire and cut a few more in different spots. Its kinda a pain to get it to work but pretty cool when it does. There is a way to get around the shock sensor but it involves running a wire back to the sensor which is somewhere in the rear of the car. Hope this helps
Cp3aight is offline
Old 02-03-2009, 10:08 AM
plays well with others
Irrational X's Avatar
Car Info: your mother crazy
turbo timers are fairly unnecessary on our cars. there was some extensive testing done and posted on the LGT forums with digital in and our temp sensors on the coolant lines.
(cant find link but im searching)
basically, with a stock or mostly stock car (stock turbo or small turbo) pulling into your driveway cools the turbo well below safe levels. unless you red line it into your driveway.
Irrational X is offline
Old 02-04-2009, 02:22 PM
soobedup's Avatar
Car Info: WRX wagon 2006
I don't have no problems with turbo timers whatsoever. Just remember your car is still running therefore your gas consumption increases depending how long it takes to cool off your car.
soobedup is offline
Old 05-04-2009, 10:31 PM
mattsn0w's Avatar
unless you're running an oil only cooled turbo, you don't need a turbo timer.
mattsn0w is offline
Old 05-04-2009, 10:46 PM
banned
C89ZX7R's Avatar
Car Info: 2004 STi
Well you can install one but its pointless if you still have the heat expansion tank on the car "metal tank with multiple hoses and a radiator cap".
C89ZX7R is offline
blue04WRX
07-11-2010 10:35 PM
grex767
05-27-2006 10:37 AM
Dirty Sanchez
12-28-2005 02:08 PM
krishna
12-04-2002 09:29 PM
Quick Reply: Turbo Timer ?'s (any problems with alarm or remote?)
