turbo help?:/
Old Nov 5, 2013 | 08:35 AM
cali_sti's Avatar
Car Info: 06 wrx sti
turbo help?:/
Hey guys so as of yesterday my turbo has not been performing the way it used too.. it went from 16psi to about 6 max now.. could it be a leak? Or a blown turbo? Im really knew at this. Any suggestions would help! Its the vf39 stock on a 2006 sti thanks again
Old Nov 5, 2013 | 09:17 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
perhaps a cracked turbo housing. notorious on vf39
check your lines.. but its probably a bigger crack than a hairline crack on the houseing if it's loosing that much pressure. Time for an upgrade
Old Nov 5, 2013 | 09:22 AM
cali_sti's Avatar
Okay thanks for the quick reply! Im a little short on money.. but do you know how much an upgrade would cost? Or if anyone seeing this has one for sale locally?
Old Nov 5, 2013 | 09:53 AM
esousa22's Avatar
if you are short on money, an upgrade probably isn't the best thing but its something most of us do/will do when our turbos go out. As far as upgrading, if you are going to upgrade to a bigger turbo you are more than likely going to need a bigger fuel pump like a walbro 255 or larger and injectors depending on the turbo. Then you are also looking at a tune which runs between 3-$500. After said and done with an upgrade you are looking at a minimum of $1k and thats bare minimum and finding a used turbo and used injectors. Even $1k seems a little low.
Old Nov 5, 2013 | 10:39 AM
cali_sti's Avatar
Okay thanks for giving me a pretty good estimate. Now the other thing is installation? Hopefully someone has a used turbo thats an upgrade from the vf39 that I can buy locally. But what about installation? Are turbos pretty difficult to install? Same goes with the injectors and fuelpump? Sorry like I said im new at this... and will I have to upgrade my stock intercooler?
Old Nov 14, 2013 | 02:45 PM
strider327's Avatar
Car Info: 2005 WRX
Best thing to do is look up youtube videos and go from there in terms of installation.
Old Jan 9, 2014 | 09:42 PM
eTron's Avatar
Car Info: 2014 sti
If ur turbo s h I tted very common symptoms blue smoke outta da tail pipe intermittently then clears off especially cold starts clogged filter in the main inlet oil line banjo bolt needs to be replaced same time even on a rack it takes about 4hrs book time is 4.5hrs good luck man
Subaru AWD
Hawaii Classifieds
Oct 18, 2013 04:38 PM
JDMGC8
May 29, 2009 08:07 PM
WRX-.-v
Nov 25, 2003 10:56 PM
singsing
May 24, 2003 03:19 AM
stealth-wrx
Mar 27, 2003 11:15 AM
