.....question bout cold air intake.......
Old Jan 24, 2008 | 11:28 PM
wrxstyles's Avatar
Car Info: 04 wrx impreza
.......installed cold air intake, now i cannot screw sensor in without car shutting off, so i'm driving around with my check engine light on, what can i do?........ friend of mine said i need an adaptor, how true is this?..........
Old Jan 25, 2008 | 10:06 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Since you have not provided enough information, here's an idea:
Put your stock intake back on.
Old Jan 25, 2008 | 11:50 AM
Woodward's Avatar
banned
Car Info: 2006 Subaru Impreza WRX TR
Your MAF sensor??
Take Paul's advise and put your stock intake back on. Unless you like to run nice and lean...
Old Jan 25, 2008 | 01:27 PM
wrxstyles's Avatar
......what info do u need my nikka?...... as far as i know there's only one sensor that plugs into the cold air.......do u have a cold air on your 04 subaru wrx impreza?.......
Old Jan 25, 2008 | 01:32 PM
Woodward's Avatar
banned
PUT YOUR STOCK INTAKE BACK ON.
Obviously you have no idea what you're doing and I highly doubt that you're tuned for an aftermarket intake. Take our advice or you'll screw your engine.
Old Jan 25, 2008 | 03:57 PM
wrxstyles's Avatar
......nah i do know what i'm doing just wanted someone else's opinion....thanks but no thanks buddy.......
Old Jan 25, 2008 | 04:13 PM
pope 06 2.5i's Avatar
Car Info: o6 impreza.
wait. everything's okay. he knows what he's doing.
Old Jan 25, 2008 | 04:48 PM
Woodward's Avatar
banned
Do what you're doing then. Looks like you know what you're doing.
Keep driving around with that CEL on then. It's on for a reason. Hurry up and fry a piston so you can go back to Civics. So do you really think there's colder air in your fender than in front of your car where the stock air-scoop is?
Old Jan 25, 2008 | 07:17 PM
imHELLAslow's Avatar
Car Info: 20psi Daily!
lol +1 for putting stock airbox back in
Old Jan 25, 2008 | 07:50 PM
SLEEPERWRX's Avatar
Car Info: Subaru WRX
If the answer wasn't clear enough here's my 2cents...
CAI = CEL = "lean run condition" on my 02 WRX
Removed CAI = NO CEL = correct air / fuel mixture
per Adam @ LIC "stock air intake does a good job of providing cold air"
Old Jan 26, 2008 | 06:13 AM
wrxstyles's Avatar
.....so let me ask this question, why do they make the cold air intake for the 04 wrx impreza if its no good?.......and no one has a cold air on here?..........
Old Jan 26, 2008 | 06:17 AM
Wingless Wonder's Avatar
Most of the aftermarket intakes don't require an adapter since the intake is designed for a WRX application. This usually holds true whether the intake is the Subaru SPT intake or some aftermarket model. If the intake requires an adapter accessory for the MAF sensor, there's a good chance that the intake is some sort of universal intake and won't work correctly on a WRX without tuning - not worth the effort or money spent.
Putting the stock airbox and snorkel back on is problem-free and costs nothing. If you happened to see pictures of the Impreza rally car driven by Travis Pastrana in the X-Games, it had a factory intake and snorkel in place.
Old Jan 26, 2008 | 06:20 AM
Mostly for looks. Some intakes can make additional power but you can usually achieve the same increase (or a lot more) with professional tuning and other modifications.
Old Jan 26, 2008 | 07:18 AM
wrxstyles's Avatar
......thanku..........
Subi_Bojo
Jan 23, 2014 02:26 PM
HungrySTI4V8
May 3, 2009 07:25 AM
HungrySTI4V8
Apr 18, 2009 08:27 AM
StankFootZ
Jul 6, 2004 12:02 PM
RyanH
Feb 19, 2003 05:37 PM
