Performance at Altitude
Old Oct 24, 2008 | 09:39 PM
ethernectar's Avatar
Car Info: Was 08 Outback XT, Now 06 Sport Edition 4Runner
So I went for a drive today up over Tioga Pass (Hwy 120, Yosemite NP) and its pretty close to 10K' elevation. I started to notice it really at around 8K' - pretty sluggish in the bottom end. Like it wanted much more throttle than normal from a start. On the drive back I paid more attention to it and it seemed to go away around 5 or 6K elevation.
Is this normal for a turbo?
Old Oct 24, 2008 | 09:43 PM
PikkaGTR's Avatar
higher elevation means lesser air density
I'm sure you'll notice this with an NA car as well
an engine is nothing more than an air pump---less air less efficiency
Old Nov 3, 2008 | 05:19 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
I live in Minnesota does that count?
Old Nov 3, 2008 | 06:47 PM
Wingless Wonder's Avatar
This is normal for any internal combustion engine. That's the reason why turbocharging and supercharging are often desirable for small aircraft using car engines. Air becomes less dense with altitude. Engine management can compensate to a degree by leaning out the fuel to maintain correct stoichiometric ratio, but with less air (oxygen) in the cylinder, it's gonna make less power. Yes, it's normal to have to put your foot into it deeper as elevation increases.
If you look at ¼-mile elapsed times and mph trap speed for any given car, the performance will suffer at high altitude drag strips. Irwindale drag strip in southern California is at 250 feet above sea level, while Bandimere drag strip in Colorado is located 5800 feet above sea level. Thin air does more than affect power - it also reduces downforce on cars with aerodynamic aids.
Race cars that traverse mountainous terrain such as the World Rally Championship in the Mexican Rally and the Pikes Peak Hill Climb must spend a lot of time calibrating their engine controls for maximum power and reliability as they ascend the mountain.
Old Nov 3, 2008 | 09:41 PM
Thanks, so does it make sense that when its rainy here (at sea level +100') the car feels a little punchier? Or is that just my newfound pleasure at the sight/sound of rain falling?
Old Nov 4, 2008 | 06:54 AM
Cooler air is more dense and makes more power, hence the reason why factory turbo cars have intercoolers.
Humidity does not add power - it displaces the oxygen content of air and does not act like a water injection unit, which should be calibrated to work in conjunction with engine management tuning.
EtchyLives
May 21, 2004 07:20 AM
02BlkRex
Apr 6, 2003 07:19 PM
02BlkRex
Mar 24, 2003 04:39 PM
02BlkRex
Mar 24, 2003 11:30 AM
