MSD Says it doesn't work... or does it?
Old Dec 25, 2003 | 10:15 PM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
Post MSD Says it doesn't work... or does it?
I Bought an MSD DIS-2 and at first I couldn't get it to work.
SO I called MSD. THey said that it isn't compatible.
THis is why:
Our Coils have four wires:
Ground
12V+
Coil control signals x2
These control signals are a 1V waveform. They are not the grounded pulse the MSD is looking for.
Our coils have the ignitor built into them. The ignitor provides the grounded pulse required to fire a coil.
This is how I got an MSD DIS 2 to work for my car:
Hacksaw and dremel. I cut apart the stock coil in order to pull the ignitors out of the coil. This was slow and messy. It could be easily screwed up, but luckily I did it right the first time.
Each ignitor has three terminals:
Coil negative,
Ground
Control signal
I soldered new wires onto these terminals. Ground was wired to ground. Control signal goes to the wiring harness signal from the ECU, Coil Negative to the MSD control input.
THen I had to buy an aftermarket coil. I bought the MSD 8229. IT is a four post two coil pack for Neons and Eclipses. Attached the coil to the MSD and fired it up.
Works good so far... I haven't left the driveway. Here are some pics.
Old Dec 25, 2003 | 10:17 PM
my2003wrx's Avatar
Sorry but what does it do?
:banana:
Old Dec 25, 2003 | 11:25 PM
ImprezaRSX's Avatar
Big Baller
Built-In Features
Program two rev limits for consistent launches and over-rev protection.
Retard the timing at top end to prevent detonation.
LED monitor will alert you of a low supply voltage or faulty input signals.
Ignition Interrupt will prevent the engine from starting by disabling the output to the coil.
MSD DIS-2, PN 6211 (2 Channel Ignition)
MSD DIS-4, PN 6215 (4 Channel Ignition)
Maximize your vehicle’s distributorless ignition system (DIS) with MSD’s powerful new ignition controls; the MSD DIS-2 and DIS-4. These Ignition Controls feature Multi-Channel capability, and can deliver up to 480 volts to the primary side of most DIS type dual output coils. With its two channels, the MSD Digital DIS-2 is designed for use on all 4-cylinder applications using 2 coils, while the DIS-4 can be used on all 6 and 8-cylinder engines with three or four coils.
These new DIS Ignitions feature the race proven capacitive discharge, multiple spark design of the MSD 6 Series Ignitions. Each spark of the MSD Digital DIS Ignitions is packed with up to 115 millijoules of spark energy, resulting in more efficient combustion to produce more power. To improve low speed throttle response, smooth out the idle and stop low speed spark plug fouling our engineers included MSD’s proven multiple spark discharge feature. This race tested design produces a series of full power sparks that last for 20° of crankshaft rotation to ensure complete combustion of the fuel mixture!
The MSD DIS Ignition Controls are an incredible breakthrough for late model Mustangs, Grand Nationals, Talons, Mitsubishi GT 3000s and a list of other DIS Ignition equipped vehicles. With the proven MSD Ignition high speed RISC microcontroller technology and years of performance ignition experience, the MSD DIS Ignition Controls will make a great addition to your car!
Soft Touch REV Control
The DIS-2 and DIS-4 both feature an adjustable built-in Soft Touch Rev Control to protect the engine from overrev damage caused by missed shifts or broken driveline components. This feature produces a smooth rev-limiting action by randomly dropping one cylinder at a time and then refiring that cylinder on the next firing cycle. This feature is easily adjusted with simple program switches mounted on the side of the unit.
Two Step Module Selector
The Two Step function of the MSD Digital DIS Ignition allows you to activate a low rpm limit while staging and waiting for the light to turn green. This popular feature gives you a distinct advantage over your competition by permitting you to control your engine’s rpm precisely before every launch. With a fixed rpm limit at the starting line, each launch will be consistent and quick! The rpm limit is easy to adjust in 250 rpm increments with switches built into the side of the housing.
Programmable Timing Control
Precise timing control is essential to producing maximum engine power. With the addition of nitrous, turbos or supercharger systems, timing becomes even more critical. To get the most out of your engine, the ignition must be able to compensate for these extreme changes in cylinder pressure throughout the engine’s entire rpm range. During low speed operation, the MSD DIS Ignitions use the factory ignition to control basic timing functions. Once maximum timing is achieved, the DIS-2 and DIS-4 can be programmed to retard the timing at a specific rate and rpm point to prevent engine damage due to detonation caused by excessive timing.
LED Monitor
A built-in LED monitor is a useful tool to determine the status of the charging and ignition systems. When the battery voltage drops below 8 volts, the LED will begin flashing at a rate of two times per second, letting you know that the charging system is not operating properly or that the battery has failed. Also, if any of the ignition’s channels lose their trigger input, the LED will flash at a rate of one flash per second.
Ignition Interupt
To prevent accidental or unauthorized starting of the vehicle, the MSD DIS Ignition systems feature a driver activated ignition interrupt feature that can be used as an anti-theft device. When activated, this feature will prevent the engine from starting by disabling the ignition’s voltage output to the coil.
EMI Noise Protection
As with all MSD Ignition products, additional protection from Electro Magnetic Interference (EMI) has been added to the design of the DIS. Special circuitry filters out unwanted noise that commonly causes other aftermarket ignition systems to false trigger, operate intermittently and even fail.
MSD DIS-2 (2 Channel Ignition) - PN 6211
DIS OPERATING SPECIFICATIONS
Spark Energy: 105 - 115 milliJoules per spark
Primary Voltage: 460 - 480 Volts Delivered to Coil
Output Voltage: 40,000 + Volts
Spark Series Duration: 20° Crankshaft Rotation
Operating Voltage: 12 - 18 volts, neg. ground
RPM Range: 14,000 rpm with 14.4 volt supply
Old Dec 25, 2003 | 11:26 PM
ImprezaRSX's Avatar
Big Baller
or you can just go to www.msdignition.com and read all about it.
curveslayer
Feb 9, 2011 06:19 PM
Rocket Man
Sep 16, 2004 09:36 AM
4080wrx
Jul 11, 2003 12:13 AM
Florentina
Mar 2, 2003 03:09 AM
Florentina
Wanted
Mar 2, 2003 03:02 AM
