Intake tip
Old Aug 25, 2005 | 09:26 AM
Ichinobu's Avatar
Intake tip
Just posting something worth while for a change.
The intakes can be tricky. Most of the time they (companys) lean out the air fuel ratio (A/F) by increasing the diameter of the pipe. The unmetered air passes under the MAF sensor and makes the engine run leaner. This of course increases horse power but because the ECU is compensating for the unmetered air, it ends up running in circles trying to dial in the correct A/F. Although you are getting more horsepower your engine isn't running as smooth as it should be. You can compare this with some one who has a stock unit. Focus on the smoothness that you feel and then ride one with a intake. you'll see the difference.
The only reason that you should need a intake is if you install and Front mount innercooler or running crazy injectors that require extremely high air flow. The stock unit can handle up to 340 hp. The FMIC piping normally routes where the stock intake is. This requires you to remove the stock unit and install a ram air or cold air. Other than that you really don't need one.
Injen, K&N,Perrin and APS (all second generations only) work well, but you should use K&N's RC-9350 filter head. The others filters are too big. It's a tiny filter but it works. I used it on 2.0L and 2.8L engines. It allows the correct amount of air flow.
If you are going to keep the stock unit and you are thinking about the K&N replacement filter you need to think about this. The filters are reuseable but they require a lot of maintenance. The filter has to be coated with just the right amount of oil. Too much and it chokes the filter not enough and the filter doesent catch the dirt. You best bet is to buyt two and rotate them out, cleaning one when you have time. That way you can pop one in and clean the other when you have time.
I liked the stock filter because I'm lazy and didn't want to take the time to oil up and so forth. So if your lazy like me you better off using the throw away.
I've always preached efficient power. Don't worry about the whp number look at how efficiently fast your car can be. It will pay off in the long run.
Well, I hoped that helped out a little, Now back to the BS posting.
One
P.S. From time to time I'll post some food for thought, so keep you eyes open.
Old Aug 25, 2005 | 09:27 AM
kenji815's Avatar
Car Info: 2005 Pooparu
nice guide ichi
Old Aug 25, 2005 | 09:51 AM
BLITZSTI's Avatar
Car Info: .
nice post! i remember you telling me this ages ago.. its good that you mention this for the no0bs
Old Aug 25, 2005 | 10:25 AM
Impresive-G's Avatar
Car Info: Genesis Coupe
did i hear n00b? =D
Old Aug 25, 2005 | 10:46 AM
voipchuck's Avatar
Car Info: Saaburu 92x Aero
What about foam filter?
Thanks Ichinobu, you sure knows more than me.
That been said about air intake, what about foam type drop in filter that fits in the stock air filter location? Something similar like a perrin panel air filter type?
I would assume you would recommend, like so many others have, to not waste $ on a cold-air intake like Injen? (I just heard ppl said it doesn't do crap)
Thanks for ur recommendations & suggestions again
Old Aug 25, 2005 | 10:49 AM
SpeedRacerX's Avatar
Car Info: '03 WRX Sedan
So, for the stock airbox, which filter do you recommend?
Old Aug 25, 2005 | 11:35 AM
Ichinobu's Avatar
The foam need oil also, but they seem too porous and lets dirt in. That causes you to want to put more oil to catch the dirt but then causes another problem. The oil ends up coating the MAF sensor and throws off the ECU. After a while you will have to clean the oil off the MAF sensor and the filter. It just seem too problematic. This is fine for the race track cars, because thay run once a week or once a month. We drive everyday and in traffic, that is a big difference in what type of dirt the filter will come in contact with.
I run an Injen because of I have a FMIC. If it didn't I would still use the stock box. If you do have an Injen already just change the filter to the K&N rc-9350 and you will see a world of difference. That big *** filter that it comes with just lets in too much air in for the intake.
On the stock box. The difference would be based on your convenience. The K&N filters need to be oiled just right. If you are willing to take the time to oil it correctly then it's not a problem, but if you are like me and don't have time, then stay with the paper. You may change out the paper ones more often but you don't have the hassle with the cleaning and oiling process. The new filter out of the box is cleaned perfectly.
I mentioned buying two K&N drops , because you can clean one while you run the other. It really takes time to clean it properly and we normally want to change it and go. Having the extra one allows you to do that.
One
Old Aug 25, 2005 | 11:42 AM
BLITZSTI's Avatar
Car Info: .
One
Old Aug 25, 2005 | 11:54 AM
Ichinobu's Avatar
Thanks, BLITZ's
You are now Director of the Illustration department .
One
Old Aug 25, 2005 | 04:13 PM
jsap's Avatar
Is there any stock replacement filter like Apexi, which is dry type air filter and reqires no oiling at all?
Old Aug 25, 2005 | 10:28 PM
meilers's Avatar
I run the Perrin foam filter, and I have to disagree with these statements. I used mine for over 20,000 miles before I checked the MAF, and it was pristine, no signs of oil or dust build-up. The filer gets REALLY DIRTY, almost black in the center, but only on the intake side; I don't see anything making it through the filter.
y2Ldude
Jan 30, 2009 05:06 PM
Polish
Aug 22, 2006 12:35 AM
sloeshaun
Oct 16, 2005 07:40 PM
Slamsitin
New England
Jul 6, 2003 03:43 AM
