IAT sensor (on 2.5 non-turbo?)
Old Mar 24, 2006 | 09:28 PM
UgLiEz's Avatar
Car Info: MY05RS, MY70914, and MY10VT1300CS
IAT sensor!!!!
Can anyone with a 2004/2005 Please post a pic of the IAT Sensor (intake air temperature sensor). Thanks yall...
-Matt
Old Mar 25, 2006 | 03:02 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
its built in to the MAF
Old Mar 25, 2006 | 04:31 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Yep.. the IAT is in the MAF. This is one of the major design flaws of the Subie EM. Since the IAT is before the IC, the ECU has no way of knowing if the IC is heatsoaked or not... makes a tuner's life much more difficult.
Old Mar 25, 2006 | 05:02 PM
stg2lgcy00's Avatar
He has a RS
Old Mar 25, 2006 | 05:20 PM
slvrsubywgn's Avatar
So is there any way to "re-tap" the MAF somewhere else, possibly after the IC, to make tuning that much easier? Or would that mess with things too much and not be plausible?
Old Mar 25, 2006 | 06:04 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Generally the MAF is supposed to be downstream of the turbo because they react funny to boost. I've had a couple ideas for re-locating the IAT alone, but none of them are too easy to do and require quite a bit of work with the ECU. I haven't given up on it yet though.
Old Mar 25, 2006 | 07:20 PM
UgLiEz's Avatar
Originally Posted by stg2lgcy00
He has a RS
Yea..... I'm N/A so is the IAT Sensor still built into the MAF or is it a Seperate Sensor?
Old Mar 25, 2006 | 10:15 PM
ASpec818's Avatar
Car Info: Audi B6 S4
hey ugliez, did you get a CEL or something related to the IAT sensor?
Old Mar 26, 2006 | 09:58 PM
UgLiEz's Avatar
Naw I've just been reading up on little mods you can do to increase HP at WOT (wide open throttle) and one of em was a IAT mod. From what I've read if you put a simple resistor in the connector that goes TO the IAT sensor it will advance your timing and give ya a tad more HP at WOT. But i was just wondering. I'm really hoping to hear from some guys that do tuning to see if this is even possible. But if all else fails i'l just go get a PerfectPower ECU or something.
Old Mar 28, 2006 | 10:33 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Mods like that are never a good idea. They trick the ECU into thinking the conditions are different than they actually are. This can deffinately cause issues and is never recomended.
Old Dec 12, 2006 | 04:37 PM
lYNEl's Avatar
Car Info: 07 Forester
IAT Sensor
So it true, In the new 2.5L's the IAT is built into the MAF Sensor, But are there any Subaru Techs out there that know with of the 5 wires feeding into the MAF are for the IAT
Cheers
Old Dec 12, 2006 | 05:52 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Cheers
Take the connector off of the MAF.
Look at the connector as it fits onto the MAF.
The wire 2nd from the left ( should be) the wire you quest for.
Old Dec 12, 2006 | 11:59 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
Matt, that iat mod doesn't work...
i think your sensor was in your airbox thing you removed anyways for the Injen.
you want power? go 4-1 headers, run 91 oct 76 gas, and get a perfect power and take that **** to mike.
-Gagan
SIR_WRX
Feb 24, 2006 01:53 AM
ASpec818
Dec 11, 2005 06:54 PM
stg2lgcy00
Jan 18, 2005 05:36 PM
stg2lgcy00
Cars For Sale
Mar 31, 2004 04:31 PM
Derek800
Aug 9, 2003 11:14 AM
