i.a.c.
Car Info: 95 awd impreza
i'm having no luck on the N/A fourm my engine idle is down to 400rpm hot
what is an i.a.c.?
what dose it do?
where is it located on a 95 2.2?
can it be adjusted or should it be replaced ?
how much do they cost?
what is an i.a.c.?
what dose it do?
Idle Air Control. It's a little stepper motor that opens a valve that allows air to bypass the throttle body. It's to help control the exact amount of air going through the motor while it's turning slowly. It's the thing that allowed cars to idle so quietly you don't even know they're running sometimes. It's right next to your throttle body. If you can find the Haynes manual it should have instructions for troubleshooting bad idle.
