how to tell if its reflashed
Old Jan 3, 2006 | 07:26 AM
Smooth_Ej20's Avatar
Car Info: 2004 Wrx
Question how to tell if its reflashed
Well i bought my car used and the only obvious things the previous owner did was an up pipe and a turbo back. I just ordered my UTEC and it occured to me that i dont know if he had it reflashed or not. Is there anyway for me to tell if he had this done or not outside of sending my ECU somewhere? I dont want to hook up my UTEC and blow some stuff up cause it was flashed already.
Old Jan 3, 2006 | 07:49 AM
Egan's Avatar
Mastro out in Florida does reflashes and maybe able to tell you if yours is reflashed. I don't know where they are in relation to you, but it's worth a shot: http://www.mastrowrx.com
Other than checking with a tuner who has the ability to flash ECU's, I don't know of anyway for the end user to verify the flash. You can also check on the ECUtek forums: http://www.ecutek.com
The dealership you bought your car from maybe be able to put you in contact with the previous owner, and he should be able to answer any questions you have.
Old Jan 3, 2006 | 07:53 AM
Car Info: 2004 Wrx
mastro is actually in my area so its not a big deal. I just wasnt sure if there was a way for me to tell without going in.
Old Jan 8, 2006 | 03:23 PM
unstble's Avatar
Car Info: WREX
maybe by installing a boost gauge to see where the psi is at? If it was reflashed, then the psi #'s would be a little higher than the stock 13.5 (almost sure this is the stock pressure), right?
Old Jan 8, 2006 | 04:55 PM
Egan's Avatar
The boost could be higher just due to the aftermarket turboback exhaust or there could be something like a manual boost controller that Smooth_EJ20 didn't see in his inspection. So, while higher boost could be good indication of a reflashed ECU, it may not be a definite one.
Old Jan 8, 2006 | 06:50 PM
unstble's Avatar
Car Info: WREX
How does adding a turbo-back increase the psi?
Old Jan 8, 2006 | 07:20 PM
Egan's Avatar
Boost creep.
Krinkov
Aug 16, 2010 10:15 AM
nation
May 29, 2010 05:49 PM
avatarr
Nov 19, 2003 05:47 PM
SubaruWRX88
Jun 10, 2003 09:58 AM
