how much boost
Old Mar 14, 2007 | 10:00 PM
gtfaded's Avatar
Car Info: 2002 wrx
Question how much boost
does anyone know what the stock boost is at on the 02 wrx? if i wanted to raise my boost by maybe 2 psi would it make a diff if i didnt have one stage colder plugs or is that a must have for any highier boost. was thinking of running myb 14 psi with ngk iriduims, what u think?
Old Mar 15, 2007 | 08:53 AM
Superglue WRX's Avatar
Are you coming from a DSM?
The stock boost for a WRX 2002-2005 is 13.5psi
If you want to throw on an MBC for your bugeye, keep it under 16psi to avoid causing issues. We in Subaru Land highly recommend an engine manegement system however. The most popular is the Cobb AccessPort found here....
www.cobbtuning.com
Just installing an up pipe, a turboback exhaust, and an EM system will net you considerably more power and quicker spool. Those will gain you somewhere in the area of 30whp depending on what dyno and gas you have access to. If you're the type to just mod it once and leave it alone, this is a great option (Cobb calls it their Stage 2). But that's only scratching the surface on what your car is capable of
Keep searching this site for tons more info.
yzercyber
Aug 12, 2005 03:42 PM
skimobile
Jul 28, 2005 07:14 PM
antdiesel3
Nov 8, 2004 02:56 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
