Cobb Access Port Tune Surging
Old Nov 13, 2006 | 12:44 PM
drflowers's Avatar
Car Info: 2002 Blue Wagon
I was previously running a custom tuned Xede from Vishnu until the unit failed and I lost the map. I then switched to a stage 2. I am hitting the target boost but immediately I notice that the low boxer burble was decreased with the new map. No other changes were made. I am thinking that the Copp tune does not have as much timing advance. The other unusual thing is that it pulls much harder when you get to 5000rpm and continues to pull hard to 6000 to 6500.
I have a vishnu uppipe, Turbo XS down and mid pipes with 1 high flow cat, and stromung dual tip exhaust. I am also using a vishnu underdrive pulley, K and N drop in filter and one heat range colder plugs.
Do you think its the tune or should I try something else?
Old Nov 13, 2006 | 03:05 PM
Wingless Wonder's Avatar
A custom dyno tune will almost always make more power and torque than an off-the-shelf tune. It only takes a couple of degrees less ignition advance at a certain RPM range to be able to feel the difference in torque but could be dangerous to mess around with timing without access to a wide-band O² sensor.
Old Nov 22, 2006 | 10:30 AM
Gethin's Avatar
Car Info: WRX Wagon
Messing with the timing has nothing to do with a wideband controller. If you adjust fuel then yes, you need a wideband sensor to see how lean or rich you are running. To adjust timing, you need access to EGT and also keep an eye on KC and knock.
IMHO get the car tuned my an experienced tuner.
Old Mar 15, 2007 | 02:31 PM
scarface's Avatar
Car Info: 2005 WRX STI
To add to this. What if an advanced tuner found that the ignition advance timing is 6 to 7 degrees to low. What can be done to figure this out? I know i should be making more power but he said that he couldnt apply usual ignition timing numbers on the top end.
Any input?
Thanks guys
subiracer06
Nov 18, 2011 07:52 AM
Lungulescu
Apr 25, 2010 10:39 PM
gruppe-s
Engine and Drivetrain
Dec 20, 2006 04:33 PM
FLIWRX
Nov 8, 2006 12:20 PM
mrtrex
Jun 18, 2006 10:23 PM
