How does the ECU Learn?
Old Aug 24, 2005 | 06:58 AM
sebring vetran's Avatar
Car Info: '05 WRX STi
I was wondering how the ECU really learns and how long does it take? Suppose two new identical cars sit side by side. Each driver will have different driving styles naturally. Would one car's ECU learn to run better than the other? Now suppose the drivers switch cars but bring with them their unique driving style. Would the ECU detect a difference and adjust again?
Last edited by sebring vetran; Aug 24, 2005 at 07:00 AM. Reason: miss spelled word
Old Aug 24, 2005 | 07:51 AM
Nick Koan's Avatar
Car Info: Legacy GT
The ECU doesn't learn driving styles so much, but of elevation, temperature, air, etc. I guess it could learn driving styles, between agressive and passive, but that is probably minor compared to the environmental changes.
Anywyas, how the ECU learns. Basically the ECU will put itself into 'agressive learn mode' if its was just recently reset. When it is in agressive learn mode, the ECU will keep pushing timing and fueling, until it starts to sense knock, then it backs off. It does at all RPM's, under all loads. Eventually, it will have enough data and exit agressive learning mode. From there, it will still make minor adjustments based on the environment details.
I live in an area that gets 100+ in the summer, and ~0 in the winter. Once fall and winter start up, the ECU will start advancing the timing and fueling as it starts to see an average temperature drop. It most likely won't go into 'agressive learn mode' but it will certainly start adjusting itself to the lower temperatures.
Old Aug 25, 2005 | 06:08 PM
4080wrx's Avatar
nkoan nice write up......do you reset your ecu with the seasons?
Old Aug 25, 2005 | 10:15 PM
Nick Koan's Avatar
Car Info: Legacy GT
nope. I don't think its fully necessary. Some people seem to think so, but I'm a patient man, and I'll let the ECU take care of things normally.
Jotun
Jun 19, 2004 07:16 AM
wrxicon
Feb 19, 2003 10:41 PM
02SE-R
Dec 30, 2002 07:34 PM
don-juan
Dec 23, 2002 02:00 PM
