HELP!: AP connection issue
Old Nov 19, 2006 | 02:40 PM
JRsWRX's Avatar
Car Info: 07 STI
I'm trying to connect my accessport to my computer but every time I try to sync with pc, my computer says "Accessport communication failed (5b4) Is port in sync mode?"
I have ap v1.3 and I have no idea why it's doing this.
-John
Old Nov 19, 2006 | 02:58 PM
kspek's Avatar
Car Info: non subarus
did you put your accessport in sync mode?
Old Nov 19, 2006 | 03:02 PM
JRsWRX's Avatar
Car Info: 07 STI
Yeah did that. I've read all the trouble shooting and what not but I cant get it to connect. I bought the connecter (db9) to connect the AP to my computer from radio shack, I don't know if that would matter or not.
Old Nov 19, 2006 | 03:13 PM
Daredevil's Avatar
sand paper
Old Nov 19, 2006 | 03:27 PM
mattsn0w's Avatar
where in the BA are you located?
Old Nov 19, 2006 | 04:22 PM
JRsWRX's Avatar
Car Info: 07 STI
daredevil- ¿Que?
mcdrama- I'm located in Mountain View, 94041.
Old Nov 19, 2006 | 04:36 PM
mattsn0w's Avatar
If you can't get the cable working let me know, I could come by later tonight maybe(9pm or later), or tomorrow afternoon.
Old Nov 19, 2006 | 04:49 PM
lazybummm's Avatar
Car Info: Saabaru
did you make sure the serial port is setup on the correct com port? make sure they're active as well...serial ports are becoming less and less common
Old Nov 19, 2006 | 06:11 PM
JRsWRX's Avatar
Car Info: 07 STI
Mcdrama- Whenever you can come, it doesn't matter. I'll pay you for your time too. If you do come tonight, give me a call.
Lazy- What do you mean by serial port? and yes I have the com port setup correctly and there are no other devices plugged into my computer. For the record, I have tried installing the cobb software on three different computers, all of which gave the same error.
Old Nov 19, 2006 | 07:22 PM
kspek's Avatar
different firmware?
Old Nov 19, 2006 | 07:23 PM
JRsWRX's Avatar
Car Info: 07 STI
I've updated all of my drivers. What else should I do?
Old Nov 19, 2006 | 08:31 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I think your problem is the cable. Its not a standard serial cable. Check with Cobb for the specifications on the cable and get the correct one.
Old Nov 19, 2006 | 08:49 PM
JRsWRX's Avatar
Car Info: 07 STI
I'll have to try that tomorrow, thanks ed.
Old Dec 2, 2006 | 02:48 PM
VRT MBasile's Avatar
when I first connected mine, I had to have the map software search all the ports on the computer to find the AP
Old Dec 2, 2006 | 04:04 PM
JRsWRX's Avatar
Car Info: 07 STI
I fixed the issue, it turns out it was the cable. The cable I had wasnt a null modem cable.
addicted2jayz
Nov 11, 2010 04:31 PM
kyoung05
Jan 31, 2010 11:40 AM
Rick539
Oct 24, 2007 10:20 AM
Mach5WRX
Mar 6, 2007 06:58 AM
