Generic Stage 2 map or Reflash?
Old Jul 10, 2008 | 06:53 PM
jinorazi's Avatar
Car Info: 05 cgm imp
is running a generic stage 2 map from cobb's website ok for my set up?
just high flow cat tbe and k&n intake.
and i tried running launch control map but doesnt seem to work...anyone know the problem? when i try to get into launch rpm settings and such it says "load LC map". i'm running stock perm. map and stage 2 LC on real-time map, does this matter? need i relfash the ecu with stage 2 lc map permpanently?
Old Jul 25, 2008 | 01:09 PM
JRsWRX's Avatar
Car Info: 07 STI
Yeah the cobb OTS map is fine for your setup although you would make more power and driveability if you went with a protune. I'm not sure what's wrong with your LC map since I've never used them, but it sounds like it's setup right.
-John
Old Jul 25, 2008 | 01:11 PM
pablo_her's Avatar
Car Info: 08 silver sti
i think but i am not sure launch control is only for 06 i might be wrong
Old Jul 25, 2008 | 05:30 PM
jinorazi's Avatar
i set up lc map to perm. reflash and it works however, i used for one day and got rid of it, because it also had flat shifting and that annoyed the crap out of me.
Old Jul 26, 2008 | 09:00 PM
Lboogie's Avatar
banned
Car Info: 2007 WRX Limited | vf43'D
go to the tuning forum on NASIOC, JOhn from Cobb has some Beta's of updated maps.
Old Jul 27, 2008 | 12:33 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
You can essentially disable FFS by raising the FFS limiter up to about 6800RPM. Then it won't get in your way and you can still enjoy launch control
Old Jul 30, 2008 | 10:57 AM
jinorazi's Avatar
ahhh never thought of that.
anyways, i just keep hearing that LC is bad for the engine from everywhere...and i get a sense of accomplishment when i launch my car right on my own
Old Jul 30, 2008 | 10:04 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Yea... if you're good at launching, LC really only helps with large turbo cars that need help spooling off the line. With the stock turbo a good drive can usually launch better without it. Mediocre drivers become much more consistent with LC, however.
lburrrna
Jun 28, 2006 05:26 PM
carletto
Jul 23, 2005 03:20 PM
EJ20T
Jan 7, 2004 09:34 AM
wrxn'sx
Sep 12, 2003 11:32 AM
Top
