fuel cut off question
Old Jan 7, 2003 | 02:31 AM
scoobiesnacks's Avatar
lower the boost
Old Jan 7, 2003 | 04:33 PM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
'which' unichip? Vishnu? you can get the EMI adapter from Vishnu, or a fuel cut defender.
Old Jan 8, 2003 | 12:44 AM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
most likely, you will loose boost in all gears, ... you're turning the boost down.
When I asked what unichip you're using, I meant where did you buy it from? And How is it hooked up? Are you using a Vishnu PnP harness, or TurboXS?
What 'conditions' are you hitting boost cut? Are you rolling on the throttle on the highway? as you said you're only hitting it in 4th and 5th? what is your boost set at normally? And exactly how much 'overboost' are you getting?
like I said before, you can buy a Vishnu EMI Adapter or fuel cut defender that will solve your problem.
Old Oct 7, 2006 | 05:30 PM
axelthrasher's Avatar
Car Info: Subaru
I think I am having this problem... I'm sorry to bring back such a dead *** topic, but my car boosts at 22 PSI and it starts misfiring with the turbo xs utec... and then when I come back down to idle it throws a **** load of white smoke, my friend has informed me that the base map is throwing way too much fuel in and that's the reason for the white smoke and the misfires. So if someone could clearify this I would really appreciate it.
Old Oct 9, 2006 | 11:47 AM
black smoke is too rich
white is trouble
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
silver ghost
Dec 26, 2004 07:11 PM
pacobeagle
Jun 16, 2003 03:10 AM
spectra
Jan 24, 2003 05:12 AM
